Instrument lights failure
Old Oct 1, 2003 | 07:43 AM
jrs_big_ford_f150's Avatar
jrs_big_ford_f150
Question Instrument lights failure
Hey all, I have a odd sort of problem. Seems my dashboard lights and A/C control panel lights all go out intermitantly. Radio is aftermarket and not affected. The lights don't flicker like its a loose wire that is wiggling. Its more like they are on or off. The position of the headlight switch does not affect the lights at all. In all respects the headlight/ dimmer switch is fully functional. I am not blowing any fuses so I don't believe it to be a power problem. I think its more along the lines of a bad ground. Like i said before the lights don't flicker so I don't suspect a loose wire. Any ideas on where to begin? Any help would be greatly appreciated.
Old Oct 1, 2003 | 10:14 PM
Franklin2's Avatar
Franklin2
You could do the old "take it apart and put it back together" trick. Take the dash out, un-plug and plug everything back in, and it might fix your loose connection.
Old Oct 6, 2003 | 07:44 AM
jrs_big_ford_f150
Update : I now have total failure of instrument lights. Are the instrument lights fused in the fuse block? There is a fuse socket that is empty, and not sure what to do. Any help will be greatly appreciated as I don't like being in the dark.
Old Oct 6, 2003 | 01:24 PM
Franklin2's Avatar
Franklin2
There is a separate fuse. Here's a diagram.
http://www.cybrrpartspro.com/Chilton.../84926100L.gif
Old Oct 6, 2003 | 10:29 PM
jrs_big_ford_f150
Thank you for that link Dave. Turns out the fuse was bad. I had inspected all of them before. The 5 amp one looked like it was good. No burn marks and no break in the line. Looked good till I tested it with the meter. Thank you again for the help Dave.
300sixnick
30
Jan 21, 2014 11:06 AM
ghunt
16
Dec 31, 2008 05:25 PM
djjoshuad
1978 - 1996 Big Bronco
Sep 7, 2006 01:31 PM
djjoshuad
Electrical Systems/Wiring
Sep 4, 2006 06:52 AM
nhawki00
Feb 15, 2005 07:08 PM
