Flickering lights
Old Dec 31, 2008 | 09:04 AM
ghunt's Avatar
ghunt
Flickering lights
I have noticed lately that when I have my headlights on, sometimes the dash and radio lights will flicker, and it seems to be getting worse lately.
Also, a few nights ago I was at home with the headlights on, and noticed that when the dash lights flickered, so did the headlights.
Could this be caused by a headlight switch that's going bad? I don't really know why it does it. They'll flicker when I'm sitting still, and bumps don't seem to affect it.
Old Dec 31, 2008 | 09:15 AM
starmilt's Avatar
starmilt
If it has no relation to engine rpm's probably something going on with your switch.
I hate trying to run down intermitten problems though.
Old Dec 31, 2008 | 11:15 AM
ghunt's Avatar
ghunt
Nah...it seemingly has nothing to do with anything, just random.
I hate intermittent electrical problems too. Well anyway maybe I'll try replacing the headlight switch and see if that helps.
Old Dec 31, 2008 | 11:48 AM
starmilt's Avatar
starmilt
Just food for thought have you ever changed your lights to the relay system These take a major part of the load off the switch making them last a lot longer.
Old Dec 31, 2008 | 12:04 PM
F250FarmBoy's Avatar
F250FarmBoy
I bought a kit from LMC a week ago and have yet to get it, which is weird because I usually get things from them in a day or 2...
Here's the page, its the very last item:
LMC Truck Parts - Page 60
Old Dec 31, 2008 | 12:07 PM
Dodge/Cummins's Avatar
Dodge/Cummins
Could be your voltage regulator too.
Old Dec 31, 2008 | 12:37 PM
ghunt's Avatar
ghunt
Relay system? Nope, I've heard about doing it on other vehicles but not on my truck. Have a link to a writeup?
Old Dec 31, 2008 | 12:58 PM
starmilt's Avatar
starmilt
https://www.ford-trucks.com/article/...ay_System.html
here is one if it works(old geezer=computer dummy).
Old Dec 31, 2008 | 01:02 PM
starmilt's Avatar
starmilt
https://www.ford-trucks.com/article/...r_Brights.html
It worked I'm getting younger all the time maybe one of these years I will work on the picture thing. Heres another one.
Old Dec 31, 2008 | 01:13 PM
joe f350's Avatar
joe f350
i know about having wireing problem not fun
Old Dec 31, 2008 | 01:38 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Headlight relays are the only way to fly.
Old Dec 31, 2008 | 02:26 PM
starmilt's Avatar
starmilt
What he said. Ghunt I run 100 watt high and 55 watt low beams offroad lights in mine.
The stock headlight switch will not take this and I suspect the dimmer switch would get hot too.
Old Dec 31, 2008 | 02:41 PM
PLC7.3's Avatar
PLC7.3
If you have the OEM alternator mine did the flicker too... mine was the brushes were almost done. Check your charge voltage..... 14.3 running with lights on.
Old Dec 31, 2008 | 04:17 PM
F250FarmBoy
The harness is ridiculously easy to install. I got it around 3:00 today. There are 2 plugs that go in the bulbs, 2 grounds, 1 plug to go in one of the old head light plugs (the other is left to do nothing, it just hangs there), 2 plugs that go into supplied relays, and 2 connectors that hook up directly to the (+) batt term. and everything is labled.
I have pics I'll put up later if you cant understand what I'm trying to say.
Old Dec 31, 2008 | 04:46 PM
starmilt's Avatar
starmilt
Is the nothing one labelled? What brand is it jacobs had one several years ago but I never laid eyes on one.
