1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Front axle shafts - where to buy?
Old 03-20-2019, 01:40 PM
FractureCritical's Avatar
FractureCritical
FractureCritical is offline
As has been my luck as of late, I pulled the right front hub of my 01 F250 thinking a grinding noise was the hub vacuum seal. Unfortunately, the u-joint seized solid and cranked the ear on the inner shaft, which is now trashed. The outer shaft looks to have seen better days as well.
Im looking for a recommendation for where to get a new right front shaft assembly at a decent price. Rock auto is out of stock, dealership/OEM pricing is nuts, and I haven’t had a lot of luck on the used market.
Old 03-20-2019, 02:46 PM
99f350sd's Avatar
99f350sd
99f350sd is offline
Used junk yard or ebay...just do a lookup on the internet. If you get a used one get a spicer life joint and throw it in. That would be a dana 60 correct?
Old 03-20-2019, 02:54 PM
Skip1970's Avatar
Skip1970
Skip1970 is offline
should be dana 50
Old 03-20-2019, 03:18 PM
99f350sd's Avatar
99f350sd
99f350sd is offline
Oh yea even some 2002's had the 50.
Old 03-20-2019, 04:32 PM
SuperDutyScaler's Avatar
SuperDutyScaler
SuperDutyScaler is offline
The 7.3 powerstroke had the Dana 60 regardless of year I thought?
Old 03-20-2019, 04:50 PM
99f350sd's Avatar
99f350sd
99f350sd is offline
Never heard of that one. The DRW had a 60.
Old 03-20-2019, 05:31 PM
SuperDutyScaler
Could have sworn my dads 2000 7.3 are had the Dana 60...remember when I was buying my 2004 f350 the service manager was telling him all 7.3 had the 60 and the 5.4 and v10 had the 50 till ford changed it in 2002
BUT most employers at ford dealers are idiots so
Old 03-20-2019, 05:40 PM
FractureCritical
Mine is a Dana 50.
scarce finds on flea bay
Old 03-20-2019, 06:04 PM
SuperDutyScaler
I've never seen a 50 blow apart and I've seen chipped up 7.3 in sled pulls etc...but because I'm OCD (this wouldn't be under that actually) I'd install a 60 just because
Old 03-20-2019, 06:52 PM
Skip1970's Avatar
Skip1970
Skip1970 is offline
our 7.3 00 and has dana 50, our 99 had 5.4 and dana 50
Old 03-21-2019, 08:44 AM
brian42's Avatar
brian42
brian42 is offline
I don't know what they have now but I've sourced axle parts over the years through Northern Drivetrain, Drivetrain America, and Torque King (Quad4x4).
Old 03-21-2019, 08:53 AM
SnowPlowDriver's Avatar
SnowPlowDriver
SnowPlowDriver is offline
Plenty of axles at car-part.com.
Old 03-21-2019, 04:05 PM
FractureCritical
this and thank you.
$130 shipped for the whole assembly.
barko4
07-08-2016 05:32 PM
Crash16
02-08-2016 06:14 AM
Built_Ford_Tough_757
07-08-2009 11:24 AM
rusty350250
02-10-2006 08:09 AM
Quick Reply: Front axle shafts - where to buy?
