Dual Alternators
Old Mar 19, 2019 | 09:06 PM
ForCal's Avatar
ForCal
Dual Alternators
Shopping trucks I've seen quite a few with the dual alternators. My first thought is more stuff crammed in the engine bay and more stuff to replace down the road. Maybe I'm looking at it wrong, what is the benefit to having duals?
Old Mar 19, 2019 | 09:58 PM
Painted Horse's Avatar
Painted Horse
The Platinum and KR have so many options that require the extra voltage that it's a standard to get duals if you order the upgraded trucks.
Between Glow Plugs,Rapid Supplemental Heat, heated front and back seats, heated steering wheel etc. You can draw more current than 1 alternator can put out.
Old Mar 20, 2019 | 08:02 AM
maypo59's Avatar
maypo59
Don't forget, many tow with them, and those campers all have their own 12v needs..
Old Mar 20, 2019 | 09:12 AM
tony m 6.7's Avatar
tony m 6.7
At least there is one saving grace to LED lighting which is much less draw. But yes,as Paintedhorse said there are so many electrical needs on these new vehicles that there are definite advantages to having dual alternators. I can remember years ago when vehicles had 35 amp alternators, and many literally died when they got stranded in blizzards from all the idling and having lights, defrosters and wipers on. Boy we've come a long way.
Old Mar 20, 2019 | 11:32 AM
maxum96's Avatar
maxum96
My dad and I have towed 5th wheel RV's for years with stock factory standard output single alternator trucks without any issues. My 2019 F350 6.7 did come with the upgraded single alternator as part of a package. Unless you've got a snow plow on or some other high electrical draw device(s) [e.g. ambulance or etc], dual alternator are overkill.
Old Mar 20, 2019 | 11:36 AM
wrvond's Avatar
wrvond
I’ve got two batteries, it only makes sense for me to have two alternators.
Old Mar 20, 2019 | 12:00 PM
jimzpsd's Avatar
jimzpsd
I believe the two alternators are because there is not enough room to put one conventional (large amp.)alternator. My '97 had a single alt. and dual batteries, worked just fine
Old Mar 20, 2019 | 12:32 PM
ForCal's Avatar
ForCal
Thats kinda what I was thinking too. When I shopped the last gen trucks, I don't recall seeing dual alternators on similarly equipped Lariats and wasnt aware of any problems associated with that. Its a cheap option upfront, but I image not so cheap down the road if replacement was needed. For my own use I cant see needing the duals and was just curious why I was finding so many Lariats on the lot with them.
Old Mar 20, 2019 | 12:37 PM
f350ktm's Avatar
f350ktm
We spend just enough time in very remote locations that I prefer the security of the second alternator just in case one goes out.
The problem with my plan being there is no easy way to know when one of them is out.
Old Mar 20, 2019 | 01:04 PM
GABAR's Avatar
GABAR
Question
[QUOTE=ForCal;18549896]Shopping trucks I've seen quite a few with the dual alternators. My first thought is more stuff crammed in the engine bay and more stuff to replace down the road. Maybe I'm looking at it wrong, what is the benefit to having duals?[/QUOTE
Depending on the situation, redundancy can be a positive.
The odds of both batteries and alternators failing at the same time is almost impossible.
Jakebrake
6.7L Power Stroke Diesel
23
Sep 12, 2014 09:55 AM
dieselburner
May 18, 2013 10:15 PM
speckfisher
Sep 3, 2008 07:50 PM
tthie66
May 22, 2006 11:50 PM
