New Fifth Wheel......My Turn!
When somebody calls the move from a TT to a 5er an "upgrade" I'm normally skeptical. However, I have to agree that moving from the Springdale to that Alpine definitely qualifies! I tow plenty of TT's and 5er's and quite frankly prefer pulling the TT's for various reasons, hopefully you'll find the rewards of the fifth wheel worth the extra effort.
Congratulations on a really nice rig!
Thank you all.
I think I need to adjust the pin box. I only have 3" of rail clearance. The hitch is as high as it will go. I have 1 lower adjustment on the pin box with should give me another inch. Hoping 4 will be enough. Sets nice and level as it is, don't want to go much higher.....
1. Hooking up is easier. Once the pin is in the saddle, it is harder to connect the umbilical and break away cable on the fifth. Everything is easier to reach on the TT. There are fewer steps to hook up a 5er, but a power tongue jack is almost a standard these days which makes setting the bars pretty easy.
2. Turning is easier with a TT. With a long 5er turning right at an intersection requires pulling into the intersection before starting the turn. It’s the same problem semi’s face. Traffic can be a real pain. The TT tracks more closely behind the truck and kick out is reduced.
3. Wind- the fiver is generally taller than the TT. They are the same width though, which means a fifth wheel is going to be more top heavy than a travel trailer. Also, the WDH on a TT does provide some additional down force to the TT axle(s). I feel the TT is a bit less likely to blow over than the 5er, but if it does, it’s likely to cause less damage to the TV. I had a TT blow over, it popped off the ball. I had to cut one of the safety chains to get free, but when I did I was able to drive to shelter. Another driver pulling a 5er wasn’t so lucky. It blew over, destroyed his truck and put him in the hospital.
4. I’ve seen a 5er hit an overpass, never saw a TT tall enough to hit any overpass.
A TT is more susceptible to sway than a 5er, but it can still happen and there’s nothing you can do about it but slow down. Last week I pulled a 5er 900 miles that jerked the back of my truck side to side any time I hit 65 mph. Brand new camper, completely empty. It might tow fine loaded to camp. I sure hope so!
5ers and TTS back completely differently. I tow campers ranging from 17 feet to 44 feet. I can’t back a 5er worth a hill of beans, but I can put any size TT anywhere you want it. TT’s are much easier to back up.
Finally, pulling a TT leaves the truck bed free for carrying stuff.
Those are are pretty much the reasons why I prefer a TT to a 5er. There are exceptions to everything, though. With the bedroom hanging over the bed of the truck a 5er rig is going to be shorter overall than an equivalent TT floor plan. Lots of different priorities drive the choices people make.
It's a 3710KP. We love the floorplan. (I guess we had better love it! )
Walked through many over several months and kept coming back to this model.
Ordered a new one, didn't want one that people had been pulling, pushing and prodding. Took about 3 months after the order.
C'mon Spring!
