Sponsored by: Real Truck
2008 F250 HELP
Old Mar 18, 2019 | 06:40 PM
Cb12's Avatar
Cb12
2008 F250 HELP
So getting on the interstate today and motor made a pop and I lost all boost. I was about 30 minutes away from home so limped back home and no irregular smoke from exhaust but it began to seem smokey in the cab. I assume my turbo is blown. I cant see any hoses blown off or leaks. Is the turbo just done? Not sure if it matters but the truck also has egr delete as well as cold air intake. Any suggestions?
Old Mar 18, 2019 | 06:55 PM
mastersativa's Avatar
mastersativa
Check your boots on the hot side charge tubes, I'm sure one of them is blown off or torn.
Old Mar 18, 2019 | 07:13 PM
fordman19762003's Avatar
fordman19762003
If the DPF filter has been removed you should've had smoke if the turbo went. I'd bet a boot is torn or a boot clamp broke, I had that happen more than once and you get a loud bang and loose boost and power instantly.
Old Mar 19, 2019 | 07:51 AM
sxrfun's Avatar
sxrfun
Smokey in cab you say.......Could also be a blown up pipe or bellows.
Old Mar 23, 2019 | 03:05 PM
BigMike63's Avatar
BigMike63
Did you find the problem? Same thing happened to me and I got the same responses. Still can't find the problem and it's been 3 weeks.
Old Mar 25, 2019 | 10:08 AM
Cb12's Avatar
Cb12
I did find the issue. One of the heavy duty UP pipes blew a hole in it dumping exhaughst straight into the firewall and not getting air to the turbo.
mrlpthomas
Feb 28, 2017 01:02 PM
bculp
Jan 18, 2014 01:10 PM
RideDiesel88
Nov 1, 2012 08:30 PM
expresstow
Sep 15, 2010 08:42 PM
hott-rodd
Jul 8, 2007 05:10 AM
