what octane are you using
Old Mar 18, 2019 | 03:00 PM
bedwards's Avatar
bedwards
So... after reading this post from biz4two about octane, what octane are you guys using? I've run nothing but 87 in mine since day one. I have noisy injectors but figured it was just a characteristic of the DI engine.
Old Mar 18, 2019 | 03:29 PM
PupnDuck's Avatar
PupnDuck
I've been using mid-grade (89 Octane) in my '17 3.5 EB since day one. Hot, cold, towing, not towing. Seems to work just fine. My one unscientific test took place when I had to tow a 3700 pound car on a two axle transporter. It was 250 miles each way in 80 degree weather mostly on Interstate. I ran mid-grade going one way and premium going the other way. I saw no difference in fuel mileage or performance. Like I said - unscientific. Maybe if I had been up near the towing limit and in hotter weather there would have been a difference. Oh, and pulling that trailer I was getting 11 mpg.
Old Mar 18, 2019 | 04:08 PM
IndyDog's Avatar
IndyDog
5.0 and the manual says 87 which is what I put in.
Old Mar 18, 2019 | 04:28 PM
FORD COASTIE's Avatar
FORD COASTIE
Veteran: Coast Guard
I use 87 in mine.
Old Mar 18, 2019 | 04:30 PM
GlueGuy's Avatar
GlueGuy
I use 87 octane most of the time, except when towing I will put in 91 octane. I've not had any issues whatsoever.
Old Mar 18, 2019 | 04:39 PM
Kingofwylietx's Avatar
Kingofwylietx
Originally Posted by IndyDog
5.0 and the manual says 89 which is what I put in.
I thought all the stock Ford gasoline engines that come in the F150 could run on 87. Is yours a special edition/supercharged/etc?
I tend to run mid-grade...but sometimes I do premium or 87.
Old Mar 18, 2019 | 04:49 PM
85e150's Avatar
85e150
91 or whatever the "Premium" is. 2017 2.7.
Old Mar 18, 2019 | 04:54 PM
ford390gashog's Avatar
ford390gashog
Manual states min 87.
Old Mar 18, 2019 | 05:01 PM
CR172's Avatar
CR172
With the gas prices low as they are at the moment, I've been running premium for the last several months.
Old Mar 18, 2019 | 05:27 PM
IndyDog's Avatar
IndyDog
My bad, I put in 87 but typed 89 for some dopey reason, I'll edit to correct.
Old Mar 18, 2019 | 05:52 PM
Wiggums's Avatar
Wiggums
Manual said 87 so I used 87. For the vast majority of engines, putting in 89 won't make a difference.
Old Mar 18, 2019 | 06:13 PM
jthorngate3's Avatar
jthorngate3
I have run 93 and 87 in mine, and I haven't really noticed any difference. If I end up getting a tune, it will definitely be a 93 octane tune.
Old Mar 18, 2019 | 07:15 PM
bedwards's Avatar
bedwards
thanks for the replies
Old Mar 18, 2019 | 07:24 PM
onug's Avatar
onug
I run premium because I feel the engine sounds/performs better when being lugged down the road.
Old Mar 18, 2019 | 07:38 PM
ecoboost12's Avatar
ecoboost12
I use 93 Octane Because I have a Tune and it runs allot better
