Code P208E
Old Mar 17, 2019 | 05:39 PM
RONMCHUGH's Avatar
RONMCHUGH
Romcjr
Code P208E
I got this code today . Reductant injector stuck closed bank 1 . My question is can I drive to the dealership ? What other damage could I cause by doing so ? Thanks for the help .
Old Mar 17, 2019 | 05:58 PM
TeddyD's Avatar
TeddyD
If it’s just a reductant injector, you should be able to drive to the dealership just fine. Only thing I can see happening is the truck going into limp mode because the DEF fluid won’t fully be able to spray into the exhaust. You shouldn’t cause any damage. No worries.
Old Mar 18, 2019 | 05:59 PM
RONMCHUGH's Avatar
RONMCHUGH
Romcjr
Thanks . I did a little research and found out where it's located . Pretty easy to get to , so I disconnected and checked for corrosion and then got a hammer and tapped on it like you would a starter and maybe broke it loose . Drove to work and back (50 miles) and no cel . Maybe it's all good !!!
Old Mar 26, 2020 | 11:17 AM
cpobst's Avatar
cpobst
So I got this code last night. I cleared it and drove around a bit and it hasn't came back. I was thinking about tapping on it. How has yours been since your last post on it?
Achen
6.7L Power Stroke Diesel
22
Jun 9, 2019 06:36 PM
linofuente
Nov 23, 2018 12:24 PM
kt19
Oct 27, 2014 05:37 PM
dt444e
Sep 27, 2009 06:03 PM
4inchlovin
63
Mar 25, 2008 05:14 PM
