smog pump
Old Mar 16, 2019 | 11:41 PM
three on the tree's Avatar
three on the tree
Question smog pump
Have a 78 F150 351M 2 wheel drive. C6. My smog pump is now squealing at a volume and pitch that could shatter a goblet, when it decides to voice its opinion ! Was wondering if anyone has info. to track one down ? Is the little canister air filter cleanable or must it be replaced and is there a better filter to replace it with so more air gets to the cat so it better passes emissions Just to mention the air hose comes in on the side not the back of the smog pump.
Thank you in advance for the info and help
Old Mar 17, 2019 | 10:51 AM
beartracks's Avatar
beartracks
I think I have one in the shed but I'm in ABQ
Old Mar 18, 2019 | 02:29 PM
three on the tree
Where is ABQ and what would you want for it ?
Old Mar 18, 2019 | 02:59 PM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
if you have a newer cat you dont need it. disassemble and remove the fiberglass vanes/scrapers, pack bearings and re-assemble to essentially create an indler pulley. those vanes are whats making the noise
Old Mar 18, 2019 | 03:10 PM
three on the tree
Have never pulled one apart . Fairly mechanical mind so can do it , do you have info on how to disassemble and are we talking repacking a Bering like a wheel one or is it special? Afterwards it will good for another life time lol
Old Mar 18, 2019 | 03:22 PM
KubotaOrange76
Memory is fuzzy on details
essentially the end comes off like a starter with a few long bolts. Remove rotor and vanes will probably fall out. Clean up and just push grease into the roller cage bearings. Sort of how you do spindle bearings in a 4x4 .
i had nothing to loase on a few that ive had start squaling. Tried it and it worked
Old Mar 19, 2019 | 09:27 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Smog pump is the same: 1974/79 F100/350 & Econoline all I-6 & V8 except: 1978/79 E250/350 460, 1979 E100/250 302.
The smog pump air cleaner filter is foam rubber, but Ford obsoleted it after a few years, saying it wasn't necessary. Take it out and toss it.
flkeysff
Sep 11, 2013 03:00 PM
deisele75
Nov 5, 2005 11:55 AM
97rangerguy
Jun 29, 2005 03:10 AM
unmog
Aug 1, 2003 10:55 AM
Stokes
Exhaust Systems
May 12, 2003 09:09 AM
