4.9 Smog pump or not
I believe that the bearings in my smog pump are going I have developed a whine while the truck is idling. I have removed the belt and found a ever so slight noise in the smog pump. Every other pulley is quiet. So my question is should I delete the smog pump or replace it. I do not have state inspections to worry about, but I do know the smog pump is needed for something. If I remember right is helps force gases out of the cat. Anyway what do you all think?
buzzy613
09-20-2012 11:15 PM
97rangerguy
06-29-2005 03:10 AM
