Sponsored by: Real Truck
Headlight conversion issues
Old Mar 16, 2019 | 09:53 PM
Wdnich's Avatar
Wdnich
I have spent last three hours looking for a duplicate issue and have not found it. I am converting the headlights on my 2002 F350 to 2005 headlights. New Header panel, aftermarket headlamp housings and pigtail adapters.
Everything lights fine. The issue is low beams are extremely dim, and the high bean indicator stays lit all the time. It has daytime running light option. I have done this swap
to two other super dutys without a hitch.
Does anyone have both year headlight wiring diagrams, and has anyone else encountered this issue. Any and all help is greatly appreciated.
Thanks for help
Old Mar 17, 2019 | 10:42 AM
cokeman's Avatar
cokeman
Active Streak: 30 Days
Active Streak: 60 Days
I had this same problem when I did mine. Turned out that the adapter I used was wired backwards. I don't remember off the top of my head what the color of the wires are, but somewhere I posted about my swap and the resulting discovery. You can use a test light and make sure that power is going to the terminal you expect when on low or high beams and figure it out.
Old Mar 17, 2019 | 10:47 AM
cokeman's Avatar
cokeman
Went back and found my notes from my conversion. High beam and ground was swapped on the harness I had. Once I swapped those to the correct locations, everything was fine.
https://www.ford-trucks.com/forums/1...to-2005-a.html
Old Mar 17, 2019 | 12:07 PM
Wdnich's Avatar
Wdnich
Thanks, between that and finally tracking down the 05 diagram after you said that took less than 5 minutes to fix. Thanks so much.
jbravata2
16
Aug 21, 2015 07:15 PM
cokeman
Mar 16, 2015 09:48 AM
wahlturfcare
Dec 13, 2014 09:09 PM
billy_ray90
16
Feb 18, 2014 04:40 AM
alchymist
May 24, 2008 06:47 PM
