Sponsored by: Real Truck
Fuel pump relay?????
Old Mar 16, 2019 | 06:00 PM
wizzy214's Avatar
wizzy214
2001 f250 as 4x4 5.4l ext cab long bed
where is the fuel pump relay? Can you post a picture please.?
cant find it anywhere
Old Mar 16, 2019 | 06:59 PM
Just Strokin's Avatar
Just Strokin
here is the link to the owner's manual
http://www.fordservicecontent.com/Fo.../01f23og4e.pdf
See page 176 and 177. It mentions the fuel pump and relay. The relay might be in the PCM?
Old Mar 16, 2019 | 07:02 PM
wizzy214's Avatar
wizzy214
What number? Picture?
Old Mar 16, 2019 | 07:36 PM
Slowpoke Slim's Avatar
Slowpoke Slim
On the '01, isn't it inside the passenger front kick panel? Behind the small plastic trim cover, underneath the glovebox, but it's on the sidewall, not the firewall.
Old Mar 16, 2019 | 11:32 PM
wizzy214's Avatar
wizzy214
Still looking for the answer
Old Mar 17, 2019 | 08:14 AM
projectSHO89's Avatar
projectSHO89
The location of the fuel pump relay is not listed in the owner's manual nor is it in the PCM nor behind the kick panel nor underneath the glovebox nor on the sidewall or the firewall under the hood.
On an 01 Super Duty, the fuel pump relay is located in the "instrument panel relay block" which is located behind the dash, roughly above and slightly inboard of the gas pedal. . Remove the radio to access it. Turn the flashers on and follow the clicking sound, the FP relay is alongside the flasher relay.
Old Mar 17, 2019 | 05:45 PM
wizzy214's Avatar
wizzy214
There’s 2 next to the flasher relay which one?
Old Mar 17, 2019 | 06:48 PM
projectSHO89
Other than the flasher, one is the FP relay, the other is for the trailer tow running lamps. You'll need to sort it out, I don't recall which is which off the top of my head. Switch the parking lights on and identify which relay "clicks". The other one is the FP relay.
Okay, I think l I finally found the diagram in the EVTM.
Old Mar 17, 2019 | 08:05 PM
wizzy214's Avatar
wizzy214
So if it’s not the relay what’s the next step?
Old Mar 17, 2019 | 08:36 PM
R&T Babich's Avatar
R&T Babich
What exactly is the problem?
Is the engine turning, but not firing?
Do you have fuel pressure at the fuel rail test port?
Are you getting 12v at the fuel pump connector?
Is the Inertia Switch tripped or failed and not letting 12v thru it to the fuel pump?
Old Mar 18, 2019 | 10:13 AM
wizzy214's Avatar
wizzy214
Cranks but no start, once in a while it will start and then I’ll drive it around, but when you shut it off it won’t start just cranks, it’ll start if you crank it and hit the gas tank with a mallet.
Old Mar 18, 2019 | 07:40 PM
projectSHO89
That's almost always a sign the pump is worn out.
If you'd started with that instead of getting out in the weeds about the relay location, your question would have been answered right off the bat with the answer that would lead to the actual likely fix.
Old Mar 21, 2019 | 12:54 PM
CalEx4x4's Avatar
CalEx4x4
Does sound like your pump. But just to give you another thing to worry about in the future, your fuel pump relay is probably integral to the CJB like my 2003, and is not an individually serviceable component. There are a lot of articles here about soldering in a new relay or bypassing it all together. You might want to avoid the next round of "no start" by working on this after you replace your pump.
Good luck !
Fuel pump relay installed above the passenger side foot well and wired in after the inertia switch.
Old Mar 21, 2019 | 07:10 PM
projectSHO89
The externally wired relay, as done on your Excursion, is not needed on 2001 and older SD pickups and Excursions. That modification only became necessary starting on the '02 models.
danos94
Jul 22, 2010 12:49 AM
jasonjason
Feb 18, 2008 05:19 PM
bleevan
Aug 22, 2007 03:06 AM
Randolph
Sep 9, 2006 07:37 AM
rhubarb
1983 - 2012 Ranger & B-Series
Jan 26, 2005 08:19 PM
