Oil pan dipstick
Old Mar 15, 2019 | 03:15 PM
MTB98's Avatar
MTB98
Oil pan dipstick
I'm needing to change out an oil pan on a 302. The engine block is older from early 70s so only has dipstick in front near thermostat housing. I haven't been able to locate a replacement oil pan with the dipstick fitting outside of a salvage yard where I would need to pull the pan myself. Anyone know where to get a replacement pan with the fitting or has anyone removed the fitting from an old pan and made it work on a replacement pan?
Old Mar 15, 2019 | 05:50 PM
EllieMae94's Avatar
EllieMae94
I believe the dipstick hole is in the block on the newer ones. If you just need a pan, Rock Auto usually has the cheapest prices.
Old Mar 15, 2019 | 06:27 PM
MTB98's Avatar
MTB98
Older blocks don't have the dipstick hole in the side of the block for a center sump pan. Early 80s 302 had an oil pan with a threaded fitting side of pan for the dipstick. I'm needing a source for that style of
pan or need to know if that piece could
be taken off an old
pan and installed on a new replacement pan.
kens65fb
May 12, 2018 02:14 AM
growler 300 power
Oct 9, 2007 05:11 PM
Firemudder
Apr 21, 2007 07:58 PM
bulldogcountry1
Sep 30, 2004 11:23 AM
Ringo Fonebone
Mar 16, 2004 06:46 AM
