Child seat retrofit?
Hey guys over got a 91 F150 XLT Lariat standard cab that I love. The issue is putting a child seat in it. I don't have the child seat clip, which my wife isn't too keen on using anyway. Are there any retrofit kits that would give me the lower anchors for a rear facing child seat similar to what modern cars have?
Unless you swap in seats out of a newer regular cab truck I think you're SOL here (and I'm not even sure if new trucks have the LATCH anchors in the front seat), those anchors are welded to the seat frames and the seats are engineered around them having the anchors in them to keep your kid safe in an accident. Too much liability for a company to make retrofit and someone's child gets injured or killed in a wreck from a shoddy install. Not to mention all the no-nos and negative warnings about children riding in the front seat of a vehicle (granted the front seat is the only seat in your regular cab, I would assume this isn't your only vehicle for child transport)
When properly installed with the lap or 3 point belt a child seat is just as secure as it is with the anchors. The anchors are just easier to use, your local police or fire department will gladly inspect or even install your child seat for you if you're unsure about installing it with just the seat belt.
You're good, just use the seat belt... Virginia has no restriction on car seats in the front of regular cab trucks like Colorado. I didn't believe that Colorado actually did that, looked it up, it's true... children under 20lbs and 1 year MUST be in the back seat... even if there isn't one.
loudfords
06-01-2005 10:20 PM
