Code meanings on drivetrain
Old Sep 30, 2003 | 09:16 PM
greasemonkey964's Avatar
greasemonkey964
I am trying to find out what the codes mean for my 76 F-150 4x4.
I have found nowhere that can tell me what they mean and what gear ratios the front and rear ends have as well as the tranny and transfer case. If anyone has any info please respond.
Front End - 3.50 D6TA ATC 603690-1
Rear End - WDH-AE2 6AA 3 50 9 379A
Tranny - PGB CK1 A15 D6TP ABA019348
Trasfer - NP 14 41-75 C-11865 PTZ
Old Oct 1, 2003 | 07:31 AM
BigShelby's Avatar
BigShelby
Welcome....Let me see if I can help a little with the the rear end. You have a 9 inch rear with a 3:50 ratio limited slip. The WDH-AE2 is the type of bearing which I believe determines if you have a 28 or 31 spline. 6 AA is the date it was built. The 379A is the assembly plant code. There are many members here that can go into greater detail then I have. Try going to Mil1ion's website, which has lots of info that may help as well. Hopefully they can pickup where I left off.
Old Oct 4, 2003 | 09:52 AM
pdqford's Avatar
pdqford
Hey BigShelby,
Wouldn't his rear axle code have to be "3L50" if it was a Limited Slip differential?
Old Oct 5, 2003 | 06:57 AM
BigShelby's Avatar
BigShelby
I do believe you are correct....thanks!
wyazel1
May 27, 2007 09:10 PM
z 97ford1
1997 - 2003 F150
Sep 8, 2006 04:14 PM
oldgabe01
1966 - 1977 Early Broncos
Dec 2, 2004 11:22 PM
ScottInTexas
Apr 29, 2004 07:59 PM
pademc
Mar 23, 2003 06:52 AM
