Doing Ball Joint Have One Question
Old Mar 13, 2019 | 03:49 PM
Walleye Hunter's Avatar
Walleye Hunter
I'm finishing up ball joints and need to know about putting the axle back in. What does it take to get the axle back in through that inner seal? I don't want to push on it if it's just hitting that seal in there.
Thanks.
Old Mar 13, 2019 | 04:21 PM
derek0525's Avatar
derek0525
Just push the axle in. It will just slide right in never had any problems when i have had my axles out. Yout axle tube outer seal kinda guides the axle back in.
Old Mar 13, 2019 | 05:12 PM
Fat Diesel's Avatar
Fat Diesel
Put some grease on the end of the axle so it's got a little something to slide on rather than try to tear the seal.
Old Mar 13, 2019 | 10:32 PM
bigb56's Avatar
bigb56
as the other's said and I will add that I am very gentle/careful to get the splines slid past the seal so as not to cut it.
Old Mar 14, 2019 | 08:22 AM
Walleye Hunter
Thanks, it's already sitting in there so I hope I didn't damage that seal, I guess I'll find out soon enough. I'll get out there today and finish the install. Let us pray.
Old Mar 14, 2019 | 08:28 AM
bigb56's Avatar
bigb56
You may see a few drips for a week or more if any gear oil got past the seal when it was open but it will eventually go away.
Old Mar 18, 2019 | 03:06 PM
Josh Ross's Avatar
Josh Ross
Diverdude
My '99 had guides outboard of the inner seals (near the third member). They taper inward to ease installation of the axles. I doubt you did any harm.
Old Mar 18, 2019 | 03:11 PM
Firefighter 1406's Avatar
Firefighter 1406
You should be good to go. I have done more sets of ball joints and seals on these trucks then I would like to remember. Have always done the same you did without any issue.
Old Mar 18, 2019 | 04:28 PM
Walleye Hunter
Thanks, it makes me feel better. It went together too easy if you know what I mean.
derek0525's Avatar
derek0525
That protects inner seal from getting hit.
Old Mar 19, 2019 | 08:52 AM
brian42's Avatar
brian42
Veteran: Navy
Sometimes easy is just that...easy. I've had a couple of times where the axle slid in without any problem and I thought "what did I just do". I've had other times where I've given the axle a few smacks with a dead blow (with a 2x4 between the hammer and axle) to get it in far enough to put the hub on and tighten it down.
Mine had those which gave me peace of mind. I don't think it came with all axles though. I would check in the housing with a flashlight to see if you have them in there.
Old Mar 19, 2019 | 11:09 AM
papadave's Avatar
papadave
Clean out the axle tube . I ended up pushing debris back up into the seal causing a leak and had to do it all again. Happily Free of leaks now but ....
Old Mar 19, 2019 | 02:31 PM
brian42's Avatar
brian42
Veteran: Navy
Good recommendation.
The old version of the dust seals end up coming apart in short order and my tubes had plenty of sand and dust from the desert. I taped a paintbrush to the end of a broom handle to clean them out.
big-head
Offroad & 4x4
Aug 23, 2015 10:44 AM
THEDON117
Jul 13, 2008 03:14 PM
dieselaholic
Jan 28, 2008 11:37 AM
