2008 Manual Trans
Old Mar 12, 2019 | 12:19 AM
David Wayne Wirth's Avatar
David Wayne Wirth
2008 Manual Trans
Hello, I have a 2008 Ranger 4x4, 4.0 with 410s, 5 speed manual trans, tires are 255/70/16. I was wondering if anyone knows if there is a 6 speed manual trans that will bolt up to a 4.0. The problem I have is with my new job I'm on the highway a lot more with speeds at 70 mph, I'm running at around 2700 to 2800 RPMs at 70. I thought maybe a weak/slipping clutch and had it replace 1 1/2 years ago. but that did not fix it. my last job I really did not mind the high RPMs because I was not on the highways too much. if no tranny swap can I put in a taller gear for 5 gear. I had the truck built with the 410's because I tow and use it for farm work. and now with my new job. Swapping out the 410s is not going to happen. Sorry
Thank you for any advise.
Old Mar 14, 2019 | 11:39 AM
CBB9M's Avatar
CBB9M
No known direct tranny swap nor internal tranny gear swap. Given that swapping out the 410's isn't desired, the only other way to slow things down and lessen the drinking problem that begins around 60mph would be larger diameter tires. Truth be told, numerically high axle ratios and great gas mileage on the freeway normally don't go hand-in-hand; the vehicle owner gets to choose/compromise between bottom end torque or low revs and higher freeway mileage.
dieselboys85
Sep 19, 2006 06:35 PM
w9jcm
Dec 17, 2005 02:47 PM
four-sixty-power
General Automotive Discussion
Nov 14, 2005 11:18 AM
mr_muldoon
1978 - 1996 Big Bronco
Aug 31, 2003 09:28 AM
Metalworks
Nov 5, 2002 09:37 AM
