Help with Id a 429
Old Mar 11, 2019 | 07:18 PM
Matts56F100's Avatar
Matts56F100
Help with Id a 429
Hello everyone. I have a 429 that I'm putting into my project truck. I already know that it is a 71 429 by the casting #'s. My question is the VIN that is stamped on the back of the engine. I did find that the 1st # is the year and the letter is the production plant and the rest is from the original VIN. My question is were was production plant "Z"? It clearly shows that and can not find anything. Please help.
Old Mar 11, 2019 | 07:38 PM
52 Merc's Avatar
52 Merc
Z assembly plant code was St. Louis. VIN consecutive unit number beginning with 5 would indicate a Mercury product. They built full size cars there. Chances are it came out of your grandpa's big sled Marquis. Certainly nothing high performance.
https://en.wikipedia.org/wiki/St._Louis_Assembly_Plant
Old Mar 11, 2019 | 07:42 PM
Matts56F100
Thanks for the info. I thought it was a Lincoln.
Old Mar 11, 2019 | 07:44 PM
Gicknordon's Avatar
Gicknordon
Should have the high compression heads, if you are sticking with the cast iron heads
Old Mar 11, 2019 | 07:47 PM
52 Merc's Avatar
52 Merc
What led you to believe that?
Old Mar 11, 2019 | 07:49 PM
Matts56F100
I was just going give a freshen up. New rings, seals, and bearings. Nothing fancy.
Old Mar 11, 2019 | 08:25 PM
Matts56F100
Is there a "better" pistion to run in than the OEM?
Old Mar 11, 2019 | 08:37 PM
Gicknordon's Avatar
Gicknordon
Really not many options for 429s, especially if you are planning to keep the press fit wrist pins. I think you can really only find stock style cast pistons with the press fit pins. If you are not doing a high power build and it doesn't have much wear, I would just home the cylinders, throw new bearings in, put an aluminum intake and cam in it and call it good.
Old Mar 11, 2019 | 08:39 PM
Matts56F100
I would do that but one of the pistions has a small piece that broke off at some point.
Old Mar 11, 2019 | 09:06 PM
Gicknordon's Avatar
Gicknordon
Where are you located, if you dont mind me asking?
Old Mar 11, 2019 | 09:15 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Hello everyone. I have a 429 that I'm putting into my project truck. I already know that it is a 71 429 by the casting #'s. Impossible!
There is no way, N-O-N-E that you can identify a 429 engine from the block casting number, for the simple reason that the 429 and 460 use the same block, so the casting number will be the same.
For example, block casting number: D1VE-6015-AB or A1B or A2B = Internal balance = 1971/73 429, 1971/78 460 and some 1979 460.
Mid-year 1979, FoMoCo changed the 460 to external balance, has a weighted crank spacer.
There are no before/from serial numbers or production dates, the block casting number must be known to get the correct harmonic balancer and flexplate.
D9TE-6015-AB = Some 1979 460, 1980/97 460. This only affected 1979 F150/350 & E250/350. 460 no longer available in cars after 1978.
Old Mar 12, 2019 | 04:26 AM
Matts56F100
I'm in central PA near Hershey Park. I do know it is a 429 by the casting in the crank. I was wondering if any further imfo could be had from theses #'s.
Thanks everyone .
Old Mar 12, 2019 | 04:35 AM
NumberDummy
Crankshafts have ID codes stamped on them, these are not casting numbers.
Old Mar 12, 2019 | 04:43 AM
Matts56F100
The numbers on the crank ID it to be a 429. All I asked was of these numbers on the back of the block
that are stamped in could ID it a little closer.
Casey Hope
15
Oct 7, 2017 12:18 PM
Bigct59
Large Truck
Jul 19, 2010 05:00 PM
hot-rod
27
Jun 16, 2010 08:23 PM
2bocat
Jan 15, 2006 12:18 PM
mr marvin
Sep 10, 2002 05:36 AM
