Alternator overcharging
Old Mar 8, 2019 | 07:27 PM
Wyoming Paul's Avatar
Wyoming Paul
My son has replaced the alternator because it was overcharging at 16.5V. When he installed the new one it tested at 14.5V at an idle. When he drove it around the block it had changed the voltage to 16.5V and stays there. When he accelerates the gauges on the dash go crazy, but if he disconnects the alternator the gauges do nothing. Anyone know what this is caused by??
Wyoming Paul
Old Mar 8, 2019 | 07:50 PM
Decipha's Avatar
Decipha
sounds like the voltage regulator in the pcm went bad if its a pcm voltage controlled alternator
Old Mar 8, 2019 | 07:54 PM
Wyoming Paul
How do I find out if it is a PCM controlled alt.?
Old Mar 8, 2019 | 09:42 PM
TooManyToys.'s Avatar
TooManyToys.
If you in the 6.0L forum because it's a 6.0L, then it's not PCM controlled. You're just getting bad advice.
If he's disconnecting the alternator while it's running, he shouldn't do that. It could be the sense wire connection is broken or has a blown fusible link. The sense wire is the voltage feedback that tells the alternator how much current output there should be which will also control the voltage.
Old Mar 8, 2019 | 11:13 PM
Wyoming Paul
He disconnected the Alternator when it was not running. Where would we find the fusible link to repair the problem?
Old Mar 9, 2019 | 12:24 AM
Sparky83's Avatar
Sparky83
Follow the smaller red wire down toward the starter from the passenger side + battery post. You'll find a few taped together...
Old Mar 9, 2019 | 09:50 AM
Wyoming Paul
Thank you too all who helped with this. Sparky83, you were dead on the problem, The truck is back in service with the alternator working properly. My son had replaced the small red wire with a heavier gauge, when he replaced that with the correct gauge it was back to working properly.
Thanks Again
Wyoming Paul
brian42
20
Dec 14, 2016 04:44 PM
RANGER589
May 20, 2011 08:40 AM
DK Farms
Mar 2, 2010 10:41 PM
rustyoldford
Electrical Systems/Wiring
Apr 3, 2007 03:52 AM
dtherren
Feb 18, 2007 02:13 AM
