Tapping into parking light circuit?
Old Mar 7, 2019 | 06:49 PM
nytro se's Avatar
nytro se
I want to tap into parking lights for a set of lights for side emblems. Where would the best place be to tap into, This is on a 2019 F350.
Old Mar 7, 2019 | 07:44 PM
edjunior's Avatar
edjunior
I'll be watching this...in case I want to do it also. There is a previous generation truck around our neighborhood that has done this, but his lights are way too bright. The truck is the maroon/brown, and he has the reddish/orange lights for the emblems. And they are bright. Too bright. It would look good I think if they were toned down a bit.
Old Mar 7, 2019 | 10:42 PM
honda250xtitan's Avatar
honda250xtitan
I know you can grab power from the bulb wires behind the headlights. Not sure how convenient that is though. You'll need to pull the grille, remove bolts for headlights and pull them out enough to find your wires. Also might need to loosen all the bumper bolts to get access to the lower headlight bolt between the fender and the bumper. it's stupid.
Old Mar 7, 2019 | 11:28 PM
nuctrooper's Avatar
nuctrooper
To get to the bulb lights just pull the driver side battery out. You can reach them easy from there with a simple 3 mins of work. As long as you are using low draw led lights it should be just fine.
Old Mar 8, 2019 | 06:56 AM
nytro se's Avatar
nytro se
Any where under dash?
Tyler11T
Appearance & Dress-Up
Jun 8, 2018 11:29 AM
jerseymike
May 5, 2016 05:21 PM
icentropy
Jan 12, 2014 08:59 PM
eric777
Feb 27, 2007 09:26 AM
comertrucks
Nov 16, 2005 01:22 AM
