6.2L V8 Discuss the 6.2L V8
Plugs 6.2 vs 6.4 Change Diffuculty
Old Mar 6, 2019 | 07:43 AM
ddown54's Avatar
ddown54
I watched some Videos on Spark Plug Changes and why does Ford have to make it so difficult to do a simple Plug change? From what I can see the RAM 6.4 has a simple take coil pack off pull out long plug sealing wire 2 plugs next 2 each other boom boom your done. My Ford is going to be a major undertaking it looks like. Opinions?
Old Mar 6, 2019 | 08:08 AM
saratoga2011's Avatar
saratoga2011
It isn't that hard IMO. Top plugs are simple, an 8mm screw holds the coil on. Bottom plugs can all be reached through the wheel wells if you take a total of 30 minutes to pull both inner fender liners.
It's time consuming the first time you do it but nothing is what I would call challenging.
Old Mar 6, 2019 | 09:46 AM
Chuck's First Ford's Avatar
Chuck's First Ford
as stated above...
ford design.. a little more work.. but does a better job with flame travel.. and you should Care about it..
NO car/truck maker cares about owner or mechanic issues with service...
its about the production line TIME...
my opinion. I am 68 and did mine,, myself.. at home.. took 2 cups of coffee to complete.
Old Mar 6, 2019 | 10:42 AM
ddown54's Avatar
ddown54
Thanks I needed to understand the Rationale of the separate wires and upper lower "Flame Travel" understand.
Old Mar 6, 2019 | 03:16 PM
ibdagriz's Avatar
ibdagriz
Chuck,
I made a cushion/bed on top of the radiator and basically laid down over the top to do the upper ones. I swear the lower ones were easier once you cleared the stuff out of the way.
Griz
Old Mar 6, 2019 | 08:03 PM
Chuck's First Ford
Originally Posted by ibdagriz
Chuck,
Griz
no question.. make yourself comfortable.. and wrench..
it might be work... but why make it uncomfortable...
2 good floor jacks / stands and a "Dog Bone" creeper.. for underneath
Old Mar 8, 2019 | 05:58 AM
7591250sd's Avatar
7591250sd
Do the plugs usually come out with no issues ( stripped threads ) ?
Old Mar 8, 2019 | 08:55 AM
saratoga2011
I had one break and **** my pants but the plug itself was defective from what I was able to see. I'll try to find the thread.
It rusted at the swaged joint and the threaded piece stayed in the head while the hex portion snapped off. I live in FL keep in mind so there's no rust anywhere on the truck.
Old Mar 8, 2019 | 08:57 AM
saratoga2011
As promised......
https://www.ford-trucks.com/forums/1...gs-beware.html
Old Mar 9, 2019 | 07:52 AM
Chuck's First Ford
50 years as a mechanic.. I have seen maybe 5 or 6 engines do that.. so almost ZERO will...
removed mine.. at 136,000 miles.. when i purchased it.. not one was a problem.. an its from North East Ohio.. Salt City.
I moved to Texas 6 months ago... in case you read my header.
Old Mar 9, 2019 | 09:13 AM
WayneA's Avatar
WayneA
I just changed out the plugs boots and wires on my F250 6.2L it took me 2 hours 30 mins to complete task. I pulled both wheel wells. I used 1 18” 1 10”and 1 4” extension. Used 5/8 magnetic plug socket. I did the lower 8 first the front plug on drive side was the only bear with the shock tower and steering shaft in the way. Then went to the uppers. On top I just removed the air box and went to work. The far back plug on the drivers side upper was the only tuff one and it was not real hard. The 2 1/2 hours it took could have been shaved done but I was in no hurry and had to have a few beers between plugs.
Old Mar 10, 2019 | 04:01 PM
ddown54's Avatar
ddown54
Originally Posted by WayneA
I just changed out the plugs boots and wires on my F250 6.2L it took me 2 hours 30 mins to complete task. I pulled both fire walls. I used 1 18” 1 10”and 1 4” extension. Used 5/8 magnetic plug socket. I did the lower 8 first the front plug on drive side was the only bear with the shock tower and steering shaft in the way. Then went to the uppers. On top I just removed the air box and went to work. The far back plug on the drivers side upper was the only tuff one and it was not real hard. The 2 1/2 hours it took could have been shaved done but I was in no hurry and had to have a few beers between plugs.
You mean wheel wells? The Firewall is between the engine and cabin?
Old Mar 10, 2019 | 09:18 PM
WayneA's Avatar
WayneA
yes that is correct must of had a brain strain.
Old Mar 11, 2019 | 07:00 AM
llmflyfisher's Avatar
llmflyfisher
Never seize?
Would it be a good idea to pull the plugs right off the bat brand new truck and put never seize on threads to ensure easy serviceability at 80 to 100k miles down the road? Before they even have a chance to get stuck in place...
Old Mar 11, 2019 | 12:08 PM
kry226's Avatar
kry226
I don't think I would do that. Knowing these plugs are prone to "stuckage," I'm thinking of a 50k interval, give or take. Never-seize might be on the 2nd set of plugs, though.
Flatbed Ed
6.2L V8
Feb 24, 2016 07:51 PM
wkbrdtx
17
Jul 14, 2013 02:00 AM
MikeAubrey
Jul 2, 2007 08:28 AM
hucklebuck
18
Apr 21, 2005 04:55 PM
2000Expy
Jan 15, 2005 09:07 PM
