Constant power to embedded modem?
Old Mar 5, 2019 | 04:59 PM
Dcwampler1981's Avatar
Dcwampler1981
2019 F350
Is there a way to get constant or key on power to the embedded modem?
I work 12+ hours out of my truck and send reports with my laptop. I have to run the engine to get power to the modem for my hotspot. And my engine idle hours are racking up.
Edit: It works with key on/engine off, but power to everything. I'll just have to be sure my lights and blower motor are off.
Old Mar 5, 2019 | 08:40 PM
riveted's Avatar
riveted
Trailering
Great question. I'd like to find a fix for this one as well.
Old Mar 5, 2019 | 08:43 PM
Xwild's Avatar
Xwild
Wow.. that does seem odd that they'd make it on engine-running power only. But, I've seen weirder decisions.. Hope you find a solution.
Old Mar 5, 2019 | 08:45 PM
mhoefer's Avatar
mhoefer
Power on through an always on Upfitterr switch, that way, if you want to leave upfitter 5 on, and have switched it to always on, your modem will have power, but if you want to leave it off, just turn off the switch. That way it’s not always running at home, but on at work.
Old Mar 5, 2019 | 09:37 PM
ford390gashog's Avatar
ford390gashog
I thought the hotspot came on with the Sync? If so just change the timeout of the sync with forscan to 60 mins.
Old Mar 6, 2019 | 07:49 AM
Dcwampler1981
That's what I'm trying to figure out how to do. I'm not tech savvy, but if someone shows Pics of where the wires I need to cut and spice, I can get it done.
Old Mar 6, 2019 | 10:25 PM
TeddyD's Avatar
TeddyD
When I am sitting in my truck at work with the truck powered down completely, I just push the power button on the radio and sync turns on. I’m not sure how long the timeout is on that feature. I don’t have to even hit the push start button once. Anyone know the factory timeout on that?
Old Mar 6, 2019 | 10:29 PM
Dcwampler1981
The modem doesn't come on with the radio/sync.
Old Mar 6, 2019 | 10:37 PM
TeddyD's Avatar
TeddyD
Now I know. I use an air card so I haven’t tried it before.
Old Mar 7, 2019 | 11:51 AM
Cpt. Slow's Avatar
Cpt. Slow
Eek, I was planning on using the hotspot modem to work in my truck camper.
So I have some clarifying questions:
Does the engine needs to be running to use the hotspot ?
Or.
Can the hotspot work on accessory and if so there is there a automatic timed shut off of the accessory mode?
And.
If either of those are true, is it possible/easy to change the powering of the modem to one of the upfitter switches?
Old Mar 7, 2019 | 12:49 PM
Dcwampler1981
Or.
And.
I figured out yesterday: the modem works with key on engine off. Does not work in ACC. I'm in the process of finding out about the upfitter switch.
slinky_70
May 11, 2016 05:30 PM
smarty39
May 12, 2015 09:25 AM
zstyle01
27
Jun 21, 2007 09:24 AM
jcs1966
Electrical Systems/Wiring
Sep 25, 2001 07:41 PM
