Red Head steering
Old 03-05-2019, 10:51 AM
beartracks's Avatar
beartracks
beartracks is offline
Red Head steering
I recently install a 15:1 Re Head steering box. Mongo like! However it's much tighter than the old one. I realized the old unit was probably a little loose but I'm wondering if anyone had similar experience. In other words it takes more force to turn.
Old 03-05-2019, 11:45 AM
440 sixpack's Avatar
440 sixpack
440 sixpack is online now
Received 1,549 Likes on 1,137 Posts
Very common. they are much stiffer at first than typical cheapo Chinese reman boxes.
They'll loosen up but sometimes it takes a while.
Old 03-05-2019, 01:57 PM
Aaron-71's Avatar
Aaron-71
Aaron-71 is offline
Standard turning ratio was 18:1 was it not?
Old 03-05-2019, 10:42 PM
ranger140892's Avatar
ranger140892
ranger140892 is offline
Yeah, mine is a little firmer than original, but feels perfect to me and everyone else that's driven it. Did you bleed / burp it properly? I bled mine a lot more than Redhead's instructions stated.
Old 03-06-2019, 05:01 PM
tbear853's Avatar
tbear853
tbear853 is online now
Received 1,296 Likes on 1,096 Posts
Mine firmed up with ReadHeadSteering box …
… because the ReadHeadSteering box eliminated all that slop that was there at just over 105,xxx miles … slop where the wheel moved a good deal before anything actually moved below the OEM box. .
Now, I can drive it and no longer swing the wheel left-right-left just to go straight. I had "sat on the fence" for several years wanting the ReadHeadSteering box and so I went for it in Dec 2013 as I recall …. very nice still. I never asked about a faster ratio like moving 18:1 to 15:1 (I ordered on a Monday, box arrived that same week, on Tuesday in Va., and then Friday I sent core back … and by the next Tues or Wed, had credit back on CC) but seems a good idea.
Old 03-07-2019, 04:09 AM
matthewq4b's Avatar
matthewq4b
matthewq4b is offline
A little firmer is fine as long as there are no firm spots the effort should not change from lock to lock. Also be sure that you are using type F trans fluid for power steering fluid.
Old 03-07-2019, 09:37 AM
beartracks's Avatar
beartracks
Thanks guys, and on to the next project!
Old 03-07-2019, 02:45 PM
EQCMCAT's Avatar
EQCMCAT
EQCMCAT is offline
Beartracks,
Check W/Ryan at Blue Top, he a cousin of the owner from Red Head. Ryan (Blue Top) used to work for his Cousin and then branched out on his own.
fordboy67
06-08-2013 05:59 PM
HOODRAT
08-20-2012 08:29 AM
Greenlawnracing
1999 to 2016 Super Duty
25
05-19-2010 11:53 AM
slopdogg250
02-02-2010 09:52 PM
peglegger
09-06-2009 07:39 PM
Quick Reply: Red Head steering
