Removing head 01 E250 5.4 2
Old Mar 3, 2019 | 11:14 AM
yorkee's Avatar
yorkee
Might need to remove head to due to broken spark plug. Can the head be removed without pulling engine? Thxs
Old Mar 3, 2019 | 11:25 AM
Conanski's Avatar
Conanski
I'm not certain but I seriously doubt it, I don't see you getting the cylinder head bolts out.. hell you may not even be able to get the valve covers off.
Old Mar 6, 2019 | 10:54 PM
dziwei's Avatar
dziwei
I removed the valve covers from an '02 with the 5.4l in place, didn't go any further than that though. I can't remember exactly how tough it was other than I didn't have lots of choices for deep sockets or wobble extensions, seems like I used a combination wrench and standard 1/4 socket (PITA)... whole upper intake was off at the time for sure, fuel rail, injectors, plugs etc. seems there was heat shield/sound deadening material that I slipped out to get 1/2" more room at some point but that van was headed for scrap so you're results may vary.
Old Mar 8, 2019 | 01:55 PM
jeffreyclay's Avatar
jeffreyclay
Don't be so pessimistic! You can do wondrous things with a #4 tip in a cutting torch & air chisel.
Old Mar 8, 2019 | 05:44 PM
Im50fast's Avatar
Im50fast
V10 van: both cylinder heads removed without removing the engine.
Jeff Sims
Modular V8 (4.6L, 5.4L)
Mar 15, 2016 08:44 PM
CHOPTASTIC93
1997 - 2003 F150
Jan 27, 2014 09:14 PM
kc0rey
Jun 26, 2011 05:44 AM
meanv10
Jun 22, 2009 03:56 PM
EHC112
1997 - 2003 F150
Jan 21, 2009 01:36 PM
