Dual shock set up?
Old Mar 2, 2019 | 11:20 PM
Korbin's Avatar
Korbin
Dual shock set up?
I have a 1980 f150 302 np435 4x4 I need new shocks and I was wondering if I should run a dual shock set up on the front cause I live in Arizona and I usually like to treat all my cars like full built trophy trucks😂. So I was wondering if running dual Bilstein shocks on the front would be very helpful for jumps and whoops. I can’t exactly afford very good shocks right now. And fabrication isn’t an issue for me at all.
Old Mar 3, 2019 | 04:17 AM
Rembrant's Avatar
Rembrant
You can buy the towers and lower mounts for quad front shocks, so you shouldn't need to fabricate anything. As far as I know it can all be swapped in, but somebody can correct me if I'm wrong. The dual front shocks were an option with the trailer or handling package (or both?). Not sure what years.
Old Mar 3, 2019 | 08:28 AM
Franklin2's Avatar
Franklin2
I believe they called it a "handling package". It was probably the prudent thing to order if you were planning on towing with the truck. I want to say it came with the sway bars also, but I am not sure about that.
Old Mar 3, 2019 | 03:18 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
JRS2
Nov 28, 2015 07:22 PM
351Cleveland C4
1978 - 1996 Big Bronco
Sep 10, 2014 11:32 PM
RedUgly77
16
Jun 10, 2008 10:13 AM
Psycho_bob_1977
17
May 6, 2004 09:02 AM
