Prepping a transmission case for primer
Old Mar 16, 2019 | 11:31 PM
Scotty's 52 F3's Avatar
Scotty's 52 F3
If it's easy to find another case I can see replacing it. But, what about cast iron repair plugs like they use on blocks? Can it be done to a trans case or too much load on it?
Old Mar 17, 2019 | 10:57 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Originally Posted by Scotty's 52 F3
... But, what about cast iron repair plugs like they use on blocks? Can it be done to a trans case or too much load on it?
If I correctly understand where the crack is, it's only under load in Reverse. I would think plugs have some chance of fixing it in terms of loads (provided Reverse burnouts aren't planned), but it might still be a leaker.
Old Mar 18, 2019 | 03:35 AM
TitusDH's Avatar
TitusDH
You have the case prepped perfectly clean. A dab of JB weld will adhere wonderfully, and supposedly you're all done with it. Even better, do a V-cut along the crack first, and drill it's ends to stop the crack from going further.
Old Mar 18, 2019 | 04:47 AM
JimG1098's Avatar
JimG1098
I had my manifold welded by a pro. Perhaps what Titus has said may work. Lots of good suggestions here. Not all welders can do cast iron
J ballan
Jul 6, 2018 03:54 PM
afinepoint
Paint & Bodywork
May 13, 2012 09:41 PM
86rustbucket
Paint & Bodywork
Jun 14, 2006 08:06 AM
460f250
Paint & Bodywork
Feb 15, 2005 06:45 PM
BBiffle
2004 - 2008 F150
23
Aug 4, 2004 07:17 PM
