Hard starting when cold (electric fuel pump)
Old Apr 10, 2019 | 02:38 AM
phil64's Avatar
phil64
The problem is that the first threads are shot ! When i screw the fitting (with a new fiber gasket provided in the kit) i can't lock the fitting, it slips ... Seems that the orginal carb has a "crush washer" but i don't found it when removal, i found a red or black fiber gasket ...
I just tried an O ring which is narrower + some Loctite 577 (thred lock / sealing), i test today.
Old Apr 10, 2019 | 07:37 AM
Brnfree's Avatar
Brnfree
I had so much trouble with fuel leaking right there that I went with a different inlet filter and now run a short length of fuel hose between the inlet filter and the fuel diverter valve.
I felt like the original steel line was causing an “anti-tourque” on the fitting. Now with the rubber line I can ease into the inlet filter torque without having to fight the steel line.
To do this youll need need to make a hose barb for the fuel diverter valve and use a wix 33019 or NAPA 3019 inlet fuel filter.
https://www.fleetfilter.com/filter/33019.html
Old Apr 10, 2019 | 08:47 AM
phil64's Avatar
phil64
Thanks, i just checked the result of my threaded sealant and no leakage ! But now i've put threaded sealant Loctite 577 https://www.henkel-adhesives.com/sg/en/produc
t/thread-sealants/loctite_577.html on each end so i'll not remove the metal tube between carb inlet and fuel diverter. I removed the small screen in carb so i need to put another inline filter , i'll install it before the fuel diverter.
But what is this fuel diverter ? According to its aspect it returns to tanks (via the fuel diverter) the excess fuel and looks like a filter housing. When i write fuel diverter on google I don't find this part, rather the 6 ways fuel "diverter" which is on the frame rail. Is there a filter element inside this canister ?
Old Apr 10, 2019 | 12:07 PM
Brnfree's Avatar
Brnfree
See post #12 for a good look at the diverter valve.
https://www.ford-trucks.com/forums/1...tarvation.html
Your set up is not original... very far from original. Looks like you do not have the diverter valve, only a big filter there where it belongs.
Old Apr 10, 2019 | 12:58 PM
phil64's Avatar
phil64
I've (somewhere) the "diverter valve" but this "filter" has a return line to it i suppose. Here is a better picture which shows the return line. I bought the truck as is so i can't say it's original or not but i think it needs a single return line from carb to 6-port fuel selector valves. (seems that the date shwos a replacement in 2013)
Old Apr 10, 2019 | 05:03 PM
Franklin2's Avatar
Franklin2
The diverter is to prevent vapor lock in the fuel system. Nothing fancy inside there, just a calibrated orifice that lets a portion of the fuel go back to the tank. The fuel back at the tank is cooler than the fuel sitting in the lines. The return orifice keeps the fuel circulating in the fuel lines, keeping the fuel cooler and preventing vapor lock.
Old Apr 11, 2019 | 03:49 AM
phil64's Avatar
phil64
Ok, so no filter inside.
The only fuel filter was the one in the fuel inlet so i must install a new one.
yewdall
Dec 8, 2021 08:30 AM
hillcountryflt
Mar 10, 2017 08:51 AM
Floggit
Dec 22, 2013 04:52 PM
bmoran4
Jul 2, 2013 06:12 PM
GreenMonster32
Jan 24, 2009 10:20 PM
