Leveling Kits
Old Mar 1, 2019 | 09:13 PM
mayberry32's Avatar
mayberry32
Leveling Kits
I have a 2018 250 SD Crew Cab that I just put Ridge Grappler 35's on. I want to add a leveling kit to the truck, but I don't want it fully level. I don't want the squat you get when you tow, and I pull an 8,000 lb camper and a 6,000 boat regularly. I want a 1.5 or 2" level, leaving a bit of rake on the truck. I've never had a truck leveled before, but reading about them, I see there are block leveling kits, which are simpler and cheaper, and coil leveling kits, which are more expensive. In the end, I'm not looking for simply the cheapest fix. I want the best ride, the best handling, and the overall best solution to add the level to my truck. For that small amount of level, what is my best bet, and which brands/kits would you suggest? Local Line-X shop uses ReadyLift brand leveling kit, and that's what he suggested, as he said even a small amount of lift needs to reallign the axle and adjust for different geometry. Local tire shop suggested a simple block kit and said that small amount of lift doesn't require the axle to be re-centered and only uses the blocks. Trying to decide which direction to go.
Old Mar 2, 2019 | 12:28 AM
Imadentguy's Avatar
Imadentguy
Alot of guys run the ready lift or the BDS. If you have dough to blow look at Carli. Re-align the axle with either a bracket, or buy an adjustable track bar, otherwise your truck will look like its dog tracking going down the road. Severity of dog track appearance depends on how high you lift the front end. I saw a leveled SD this morning on the way to work that had not had the front axle centered...... it looked ridiculous as he went blowing past me at 80mph. Looked like he had a diamond frame.....
Old Mar 2, 2019 | 12:38 AM
Imadentguy's Avatar
Imadentguy
Since your not looking to go up too high you should probably do a little research and consider the BDS kit
Old Mar 2, 2019 | 12:55 AM
cain0725's Avatar
cain0725
kit
i have done last two teucks with bds kit and no problens, however i have a co worker that has a full carli with coil overs. He says the ride is good as an f150
Old Mar 2, 2019 | 05:20 AM
Jointasset's Avatar
Jointasset
I’m in the same boat- I don’t want a full level. BDS has a 1” block that I’m not sure will require anything from an alignment or trackbar standpoint. I’m going to do the shocks though at the same time.
Old Mar 2, 2019 | 06:02 AM
rewillia's Avatar
rewillia
Here's mine leveled, completed yesterday; 19 SD F250 6.7L CCSB FX4, Front +2" BDS under-coil pods with new track-bar bracket and Rear -1.5" Spacer drop; Bilstien 5100's (both F&R) and Nitto RG 35/12.50/r20 F-125Q's on stock OEM 20x8J 40mm wheel set including matching 5th spare Wheel/Tire underneath.
Old Mar 2, 2019 | 07:00 AM
Spooledsrt's Avatar
Spooledsrt
Im getting a 2" trailmaster level put on my 19 f250 on monday. Ill report back. $223 installed and alignment at the local 4 wheel parts
Old Mar 2, 2019 | 08:46 AM
mayberry32's Avatar
mayberry32
So, to improve the ride that much, how much would the Carli kit cost? That changes out both the coils and the shocks, correct?
Old Mar 2, 2019 | 09:44 AM
mayberry32's Avatar
mayberry32
Also found the BDS kit that includes the Fox 2.0 shocks. How much would those improve ride quality, and would there be any net effect to towing capability compared to the stock shocks?
Old Mar 2, 2019 | 03:11 PM
DeputyDiesel's Avatar
DeputyDiesel
Ready lift coils gave me 2 inches of lift which leaves a 1 inch rake the rear
Old Mar 2, 2019 | 08:02 PM
Imadentguy's Avatar
Imadentguy
sir did you notice a change in ride quality after installing the coils?
Old Mar 2, 2019 | 08:31 PM
DeputyDiesel
The ride became a little nicer. I’m assuming from the Bilsteins that came with the kit. I did the track bar too.
Old Mar 2, 2019 | 09:07 PM
MBaldo's Avatar
MBaldo
2" BDS Level Kit
2" BDS Leveling Kit w/ 4 new Fox Shocks
35" x 12.5" Nitto RG w/ 20" x 10" Fuel Lethal Wheels
Rides very well with this package
Old Mar 2, 2019 | 09:10 PM
MBaldo's Avatar
MBaldo
Old Mar 2, 2019 | 09:13 PM
Spooledsrt's Avatar
Spooledsrt
Originally Posted by MBaldo
looks good, what offset are those? How far do they stick out?
