I did have hose failure once during a conversion,it was on a old Dodge Caravan. Did the conversion, charged it up, everything was working great. Went out the next day, no A/C. Opened the hood, and one of the hoses looked like oil had been dripped all along the hose. It was obvious it had failed. Well, finally found a new hose, and after vacuuming it out and refilling with r134a, back in business.
That's the same vehicle where I was using it all summer, patting myself on the back for nice cold A/C on such a junky looking vehicle. Well toward the end, it quit working again. Looked and found the clutch had fallen apart on the compressor. Got a new clutch, rented the installer tool, got it all installed. Went to pull a vacuum, it would not pull a good vacuum. I messed around with it trying to find where it was leaking. I don't recommend this but I have done it several times with no harm. I have a fitting I rigged up and can put shop air on the system. Did that and heard a hissing. Found out when the clutch had started falling apart, part of it flew out and was hitting the steel tubing on one of the lines, and wore a hole in it. That was my brand new lines I just had bought.
I knew I was not good enough to weld the hole shut. I filed all around it and cleaned it up really good, and put some JB weld on it. Held like a champ, vacuum it out, charged it up, had A/C again.
That is 100% aftermarket. I would at the very least replace all hoses, drier, and expansion valve and convert to R134a. Your evaporator and compressor may we worth saving.
Then again you probably need a new condenser due to the R12 style not working well with R134a coupled with the fact that aftermarket systems may be marginal to begin with.
Wait...I don't even see a compressor! Maybe just buy the whole new system like your friend said and charge it yourself.
The compressor locked up. So we removed it. I have to spots i could mount the new compressor at passager or driverside. When i look online i see that they have these compressor called sander style and the kits have clamps like what is on my system also. Are clamps ok. I see they have a piece that extend so they are different
Sanden style are good. You mean like regular old hose clamps? I wouldn't want them on my truck but I am not an expert.
Here's what you need so far:
Sanden Compressor
Drier
Expansion Valve
Barrier hose (at least 8 feet)
I would recommend buying a condenser for a 1994 F-150, It should more or less bolt in and will be much more efficient. Also you might consider that A/C equipped vehicles usually came with a larger fan or radiator and sometimes a way to increase idle speed when switched on. (to help cooling).
Im in miami heat is the last thing in my mind. I will be reinstalling bad a/c compressor the try creat a vacuum to see if it holds . if it does not and i can pinpoint i will be ordering a whole ac kit on ebay if i can pinpoint then replace that part. A friend of mines used a harbor freight air compressor a/c vacuum and said it work great
I have the Harbor Freight stuff too, and it does work fine. R134a is cheap at the dollar store, so you can get it going with a conversion kit, and if you have a small leak,, you can fix that and try again. The parts stores also carry a dye you can put in the system and that helps find leaks.
