Vacuum Routing to Carburetor
Thanks to everyone giving amazing advice and information on this forum, I have been able to fix almost everything and install my carburetor today. Everything worked fine until it was time to connect the hoses to the carb. I have been able to re-attach the ones that were still on the old carburetor, but there are a few ports on the carburetor that I do not know where they should go to, nor do I have a hose that I could attach to those ports.
I attached what I could and tried starting it. Fired right up, but even after turning the idle screw all the way out and the mixture down, it still idled fast, what led me to believe that some of those ports might be important to the vacuum system.
Below I have some pictures of the carburetor and the ports I am talking about. If anyone could tell me what those ports should be connected I would be extremely grateful.
This port is on the front driver's side of the carb
This port is on the back drivers side
The upper one seems to be the PCV valve attachment since it runs to the passenger side valve cover. The lower one is attached to the steel line that comes out of the engine. (The crappy hoses are just placeholders)
When you are tuning the carb, make sure the choke door on top is fully open. If it's shut any at all, it can cause a high idle.
Back your idle stop screw out till the idle slows down. If you can't get it slow enough, pull the vacuum line off the distributor while it's running. See if that line has vacuum. It should not. If it does, you may have it plugged into the wrong port.
Pretty sure the fuzzy hose and the and that metal line were in the place that they are in now on the old carb. Do they serve the same purpose? They both come out of the manifold. I have the PVC valve hooked up to the black hose on the driver's side. I just don't know what to hook up to the other two ports that are empty on the picture.
That fuzzy hose and the metal line route into the manifold to a "stove" or heat area. That brass nut coming out of the choke housing should be sucking air unless it's been plugged.
Filtered air comes down from the aircleaner through the fuzzy hose, and goes into the stove area where it's heated. It then continues out of the stove on the hard steel line and goes up to the choke housing where that nut is located. That is the reason it's sucking vacuum, it's pulling warm air into the choke housing so the choke will open up as it warms up.
I think you have this backwards Dave. The fuzzy hose (it is actually sheath insulation) goes to the choke housing. That sheath is there to insulate the pipe to help prevent heat loss.
The other pipe the beside the above in the intake goes to the Carb top plate and draws filtered air in to be heated and then fed to the choke housing.
The other 2 ports are emissions ports. The front one should be evap purge control and the back one should be EGR.
rthenry145
18
07-27-2018 03:13 PM
berry1234
03-09-2016 02:58 AM
pinkpantherbeekeeper
02-23-2013 02:46 PM
