64 Restoration - Brake Lines
I'm in the process of restoring a 64 F100 with a 223 and was just looking for some outside input. While replacing a rubber brake line, I broke a piece of the steel tube and decided to just go ahead and replace the whole system while I was at it. I went ahead and got some nickel copper tubing for the flexibility and appearance.
Where I'm stuck at with making my decision is whether to add a few coils to the tube under the master cylinder like the stock setup or clean it up with some straight bends. I can see both being decent and cant decide either way.
What are your thoughts? What do you think would look better once finished?
The following users liked this post:
What about cutting + flaring?
You can get tubing cutters just about anywhere they sell tools. You will need a double flare tool to flare the ends. Most parts houses have loaners but don't count on them being any good. You can spend anywhere from $20 to $500. on one of those tools. Out of the cheap ones the Cal-Van SER 161A does a decent job for the money. And will fit in a tight spot. It takes a little practice even with a good tool to get a good double flare. There are plenty of You Tube videos showing how to do it.
I had a hard time with the three flare tools I rented from the parts stores in town, eventually I used parts from two of them to get a good flare. Then I bought this tool and have never looked back.
It's pricey, and the price has gone up since I bought it but it works everytime, even in small spaces.
For the cutting tool I just bought the smallest one at the hardware store, it was less than 10 bucks I think.
Mike Shuey
03-12-2018 04:42 PM
52F1Gary
01-25-2015 08:02 PM
460 FORD MAN
13
09-14-2012 01:05 AM
