Starter/ring gear issues
Old Feb 26, 2019 | 07:34 AM
bigb56's Avatar
bigb56
Over the years I have had the occasional grinding when I go to crank, it was pretty rare and I read about others having the issue. Mine has now gotten worse and is no longer occasional but often. How have others approached this? Will just a new starter help (mine is only a few years old, OEM Motorcraft). Has anyone replaced the ring gear/flywheel? What about the mod that addresses the flawed design of the drive gear engaging on the ring gear while it is already spinning? I have heard some people install a solenoid where you can engage the drive gear before you crank thus eliminating the problem. Need to do something soon...
Old Feb 26, 2019 | 07:40 AM
Dan V's Avatar
Dan V
You are looking at a new ring gear.....trans is coming out.
Old Feb 26, 2019 | 08:32 AM
'88 E-350's Avatar
'88 E-350
The more frequent grinding is probably an indication that the ring is chewed up, but I've had bad starters on other engines grind and a replacement cured it. If you were to mod it so that the gear engages before the motor turns it'll probably compensate for a chewed ring.
Old Feb 26, 2019 | 08:36 AM
Walleye Hunter's Avatar
Walleye Hunter
Can the ring gear not be inspected but looking through the inspection cover on the bottom front of the trans?
Old Feb 26, 2019 | 08:44 PM
bigb56's Avatar
bigb56
I'm not sure if you mean there is a window or do you have to drop the cover? I'm almost afraid to look at it. I'm probably going to start carrying a breaker bar and a deep socket to fit the crankshaft bolt.
Old Feb 27, 2019 | 07:17 AM
Dan V's Avatar
Dan V
There is an inspection cover that you can remove and get a look at the ring gear. But, really, you know what the problem is. Contact a transmission shop, with the proper tools it's really not a big job. Three hours labor?
Old Feb 28, 2019 | 09:06 PM
bigb56's Avatar
bigb56
My friend had it done on a 2WD Chevy dump truck and it cost him $1,000. Has anyone tried any of the Harbor Freight transmission jacks? I already have 2 good floor jacks and 1/2 dozen bottle jacks and a roomy indoor place to work. The truck is only used occasionally right now so I can take my time fixing it. The only thing I am worried about is the transfer case going off balance and tipping everything over.
Old Mar 1, 2019 | 07:49 AM
Dan V's Avatar
Dan V
I've done it on a couple. The first I did laying on my back with a cheap trans jack....works. The last couple I did with the help of a pit and a trans jack...much better to be able to stand up and wrench. You can remove the transfer case pretty easily, a couple of nuts/bolts to remove and a new gasket.
jvmcc
Jul 10, 2016 09:50 AM
Aune163rd
Jul 25, 2011 12:59 AM
59INA40
Aug 4, 2010 06:09 PM
sammycooks
Jun 1, 2010 05:11 PM
broncofixer
Bronco II
Aug 15, 2004 04:41 AM
