Backup Camera Zoom not working
Old Feb 24, 2019 | 07:03 AM
BlackSTXFL's Avatar
BlackSTXFL
I posted this request on the Forscan Thread but got no bites, that thread is huge though so no hard feelings.
I Basically added SYNC 3 to a non SYNC truck. I installed an APIM and an ACM. I have the factory cargo camera and the factory backup camera that came with the truck.
The cargo will zoom but the back up will not, the icon is on the screen and it beeps when I hit it just no zoom. I also can't get 911 assist to work although I am not concerned about that as much. Wondering if I can get someone here to share as built data from a truck with both cameras for the ACM, APIM and probably the BdyCM so I can compare and see if anything is out of whack or any other suggestions you have.
I successfully added a steering wheel with right side controls as well as Fords blue tooth microphone, the gps antenna for the compass and the door key pad, so stuff is working I just have a bad code somewhere.
I found a few threads where people attempted to start and as built pool but don't see a ton participation on the 17 plus.
On another note yesterday we added gps to a buddies 15 F150 Lariat, that was pretty cool.
I've learned a ton of cool stuff here and you guys share a lot, I try to contribute back where I can but have only had this thing for 5 months.
Thanks
Old Feb 24, 2019 | 08:44 AM
BlackSTXFL's Avatar
BlackSTXFL
Or a VIN
For a truck with both cameras and I can look up your as built myself. Help brother out.
Thanks
Old Feb 24, 2019 | 08:46 AM
sdetweil's Avatar
sdetweil
Thanks
what do you need? how do I get it?
2018 360 camera kit
Old Feb 24, 2019 | 09:24 AM
BlackSTXFL's Avatar
BlackSTXFL
Thanks
2018 360 camera kit
Dies the 360 have the cargo camera on the third brake light?
Althiugh I don’t have 360 it couldn’t hurt looking at that as built. If you have forscan you could just pm your as built data file but the most simple way would be provide your VIN and Fords website will supply the as built data.
Old Feb 24, 2019 | 09:27 AM
sdetweil's Avatar
sdetweil
yes, has high mounted cam
sent vin in PM
Old Feb 24, 2019 | 09:45 AM
BlackSTXFL's Avatar
BlackSTXFL
That’s what this thing is all about.
sent vin in PM
Thanks man. This forum only works if everybody contributes. When I get home later I will take a look and report back here if I get somewhere.
bigt8600
Jan 21, 2019 12:13 PM
Arkguy
Nov 2, 2018 08:30 PM
Arkguy
Oct 25, 2018 05:48 PM
Steelhant
Aug 12, 2017 05:24 PM
jmtbiggin
Large Truck
Feb 12, 2017 07:01 PM
