Old steering post
Old Feb 23, 2019 | 06:39 AM
Calvin Thomas's Avatar
Calvin Thomas
Old steering post
I searched for it but can't find it.
There was a large thread concerning adding a steering stabilizer to a van.
Did anyone bookmark it?
Old Feb 23, 2019 | 03:40 PM
Harvard's Avatar
Harvard
Steering Stabilizers
A word from our sponsors...
POPULAR MECHANICS MAY 1973:
START QUOTE:
If too little caster exists, the car will wander and weave,
thus necessitating constant corrections in steering.
END QUOTE:
Old Feb 23, 2019 | 03:49 PM
JWA's Avatar
JWA
This might be the particular thread you're seeking: Steering Stabilizer
BTW I find it immensely helpful saving threads to subscribe to those of high interest--from there they're kept in your User Control Panel under "Subscribed Threads". You can elect to receive notifications when a new post is added or not receive notifications----they're still listed in that file on your CP.
HTH
Old Feb 23, 2019 | 06:27 PM
Calvin Thomas
Cool, Thanks
Old Feb 23, 2019 | 08:00 PM
lhoward1134's Avatar
lhoward1134
Calvin, I would consider looking into what Harvard mentioned. I recently added the Ingalls offset castor/camber bushings, and they made the van steering very stable. Also, the Ingalls bushings are now sold by Moog. I couldn't find them anywhere and settled on what I thought was a Moog product. When I got them, the Ingalls were inside.
Old Feb 23, 2019 | 08:58 PM
Calvin Thomas
Thanks ill look into that.
Not to change the subject,
But if I can find it,
Do you think a spring isolator with a1 inch lift would make things worse?
Old Feb 23, 2019 | 10:13 PM
Harvard's Avatar
Harvard
Changing the fore aft angle of the chassis will effect the run time +caster.
If the change results in a more nose down angle it will reduce the runtime +caster.
If the change results in a more nose up angle it will increase the runtime +caster.
The more +caster then the better the stability at highway speeds.
So goes the theory.
Old Feb 24, 2019 | 04:27 AM
JWA's Avatar
JWA
So goes the theory.
That's true but only up to a point---from what I've read online (take that FWIW) and talking with local knowledgeable alignment tech's anything over +5 Caster isn't good for tire wear etc. Of course Ford doesn't help with the caster specs ranging from +1 > +7 degrees.
Old Feb 24, 2019 | 10:29 AM
Harvard's Avatar
Harvard
Better tell those guys on motor cycles that are running around with 25-45 degrees of rake (caster)
Old Feb 25, 2019 | 03:20 AM
JWA's Avatar
JWA
That's comparing apples to oranges though.
Immortal_Ben
Feb 22, 2011 11:23 PM
Cornbread
Mar 9, 2005 07:41 AM
fordboy1973
Offroad & 4x4
Feb 14, 2004 10:33 PM
oujasper
Jan 8, 2004 01:52 PM
