1979 Steering Adjustment
Old Feb 22, 2019 | 07:12 PM
bigballski's Avatar
bigballski
Wanted to remove the play from the steering, as it's pretty drastic. The lock nut that was on the adjustment screw was too stuck on, I had to use a nut splitter.
Twisted the screw a quarter of a rotation, and found none of the lock nuts I purchased will fit on the screw.
What size is the nut supposed to be? The one I have that was on it has been split so I can't accurately measure it.
Is there some trick to getting the nut onto the screw?
If it comes down to it can I just put a lock washer under a regular nut if needed?
I gotta get this done asap, and I just got too frustrated trying to get the nuts I bought on.
Old Feb 22, 2019 | 07:37 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Do NOT mess with that nut! It only sets the preload for the sector shaft. Over tighten it, the box could lock up. Backing the nut off when this occurs may not solve the problem.
Is the truck 2WD or 4WD? Does it have M/S or P/S?
Old Feb 22, 2019 | 09:06 PM
mark a.'s Avatar
mark a.
I don't think it's anything special, just a fine thread, 3/8" ? maybe. It has a nylon collar in the threads. To adjust the box (the right way) you got some work to do now. I always disconnect both the steering shaft and pitman arm. It's the only way I can get a good feel for the slightest bind, this has to be right. Tighten the adjustment screw till it locks. Now loosen the adjuster a little bit and lock it down. Turn the input shaft all the way lock to lock. Keep loosening and turning it back and fourth all the way in each direction till you find the exact spot that you feel no bind anywhere in it's full travel. Once you got it, note position of the slot and back the adjuster off 1/4 turn and lock it down. You can't just go in there, loosen it and start turning the screw, that will end in disaster. Good luck....
Old Feb 22, 2019 | 10:33 PM
bigballski's Avatar
bigballski
Truck is 2WD with power steering. Hopefully I didn’t jack things up too much with the removal of the nut. I will follow the steps provided, and will most likely have a ridiculous amount of questions about them.
Old Feb 22, 2019 | 10:47 PM
tbear853's Avatar
tbear853
How many miles? Good bet you're gonna need a steering box (Red Heads are great) or just get used to it.
Old Feb 22, 2019 | 11:33 PM
NumberDummy
Special nut is 7/16" -20 and is shown as 371782-S in pic:
Old Feb 23, 2019 | 06:53 AM
bigballski's Avatar
bigballski
Odometer reads in 32,000s, and the engine was swapped but I’m guessing the steering controls are the same.
And thanks for the measurements, gonna pick up a nut today. Bought 7/16-14s and was close but not close enough.
I won’t have too much of an issue with getting a new steering box if I have to, but just safely adjusting this one is the goal for now.
Benchwrench
Sep 17, 2015 07:56 AM
Texas Outlaw
Dec 22, 2010 01:21 PM
masseysbronco
1978 - 1996 Big Bronco
Dec 22, 2006 07:25 PM
bass4163
Sep 23, 2004 10:08 PM
