how fat is my '53
My 50 F1 scaled out at 3000 pounds with a 289/C4 combo. I'm sure you could add 4-500 pounds with the bigger engine/trans combo, a/c and the tilt nose equipment. Do you have a fiberglass front end? That would shave some lb's there. You've got a lot of aluminum there, too, in place of cast iron as stock weighed. I'd be surprised if you were much over 3500.
Surprisingly enough the big Caddy engine isn't big. Weight wise, it only weighs 50lbs more than a small block Chevy. So, several hundred lbs less than a big block Ford.
Without Googling the numbers, I'm thinking the big block Ford is about 750lbs, the Caddy is somewhere around 550lbs.
Bobby
Bobby
Sschultz13
09-26-2016 09:25 PM
julian53
11-28-2010 01:36 AM
cletus_the_red
09-28-2010 10:13 AM
TxF100
08-22-2009 02:39 AM
