Front spring question
Old Feb 22, 2019 | 01:55 PM
LT1950's Avatar
LT1950
I have a 1954 f100 that I am putting together stock as possible. I am about to order new front springs as mine are in pretty bad shape. Are there more than one stock type and height spring? Also Midfifty show a 2 or 4 degree wedge that mount between the axle and spring. My truck did not have this wedge when I disassembled it. Do I need one.
Old Feb 22, 2019 | 04:56 PM
GLR's Avatar
GLR
That wedge is to change/ adjust the caster. Part of wheel alignment. Caster helps the wheels return to the straight ahead position after making a turn and also keeps the truck from pulling one way or the other when going down the road.
You might or might not need one depending upon checking the wheel alignment
Old Feb 22, 2019 | 06:15 PM
LT1950's Avatar
LT1950
thanks for the info. I will be getting new tires in the future and I will have aligned then.
Old Feb 22, 2019 | 06:25 PM
GLR's Avatar
GLR
Keep in mind that most places now just have alignment machines that"if it's in the green, it's ok" as far as specs go. And, might just set the toe (which does effect tire wear)You might have to take it to a truck shop.that knows about straight axles.
Old Feb 22, 2019 | 06:48 PM
LT1950's Avatar
LT1950
Thank you. Good advice.
Old Feb 22, 2019 | 08:32 PM
ALBUQ F-1's Avatar
ALBUQ F-1
None of the shops around here can use their machines on old vehicles, their computers don't have the specs on file. A truck alignment shop can do it "old style".
bulldogcountry1
13
Mar 14, 2019 04:20 AM
Jim40216
May 17, 2018 07:46 PM
Fummins
Mar 23, 2017 03:44 PM
granny_rocket
Dec 17, 2015 06:03 AM
omni
Aug 4, 2006 11:58 PM
