Excursion fuel issue
Old Feb 23, 2019 | 04:00 PM
Lance Helmert's Avatar
Lance Helmert
If your filter was completely plugged, I would replace the filter again. I would also run a fuel system cleaner . I like Seafoam or Amsoil PI.
Old Feb 23, 2019 | 08:36 PM
R&T Babich's Avatar
R&T Babich
Originally Posted by Gjcb1976
..... Plugs and coils are all new within the past 12,000 miles. ....
What plugs and COPs did you install? Motorcraft plugs and Motorcraft or Denso COPs?
Old Feb 23, 2019 | 08:38 PM
thor363's Avatar
thor363
After all this, he's going to come back and say, "Hey! I found a bad battery cable connection!"
Old Feb 23, 2019 | 08:56 PM
R&T Babich's Avatar
R&T Babich
Originally Posted by seijirou
.... Another cause that is down-stream of the ignition switch is the main power relay.
What relay is the "main power relay"?
The PCM has a relay in the CJB.
I think the 2003 is the same as our 2002, the Fuel Pump relay is soldered on the bottom of the CJB.
The RD wire from the battery goes to a Junction Block, then on to the CJB with a fusible link in the wire.
Old Feb 23, 2019 | 09:14 PM
R&T Babich's Avatar
R&T Babich
.... I just can't figure out the intermittent stuff. I've had fuel pumps go out before and they just quit.
I've read several times about "intermittent" fuel pumps, it's just a pump and if it is worn can get sticky causing fluctuations in output.
The Fuel Pump relay contacts can get corroded from use and reduce the current supplied to run the fuel pump motor.
The voltage may look fine, but the current capacity thru the contacts can be low.
The Fuel Pump relay is rated at 20A and if I measured our pump's resistance properly it is a 15A load..
Another intermittent might be a poor connection at the Crankshaft Position sensor or a flaky sensor.
I think that sensor is used by the PCM logic to power up the fuel pump when starting, and when running keep the pump powered and of course fire the plugs and injectors.
Old Feb 23, 2019 | 11:11 PM
Gjcb1976's Avatar
Gjcb1976
Thanks, guys! You have given me so many things to look for! One of you asked about the plugs and coil I used. I think it was the Denso, but I need to go out and check. I'm still chasing the issue down, but it is NOT the battery cable. :-) That was actually the first thing I checked because that was the issue with my wrangler last year. Anyways, I'm at the point I am just cleaning everything I can. Throttle body, IAC, MAF, fuel regulator...... I'm also checking wires and electrical connections. I will add all of your suggestions too. I keep going back to that plugged fuel filter. I couldn't blow ANY air through it when I took it off. I replaced it with a new one and then replaced that new one again tonight. It had only been driven about 100 miles, but it was pretty clear.
Old Feb 25, 2019 | 10:48 AM
seijirou's Avatar
seijirou
It very well could be in the CJB and Ford may not consider it "serviceable" but soldered to the board or modular they all still function and can fail in the same way. The PCM relay is definitely more specifically what I have in mind. Typically there's a single main power relay upstream of the PCM and other things like the injectors and the coils, so I apologize if that isn't the case for this truck. The PCM relay would be what I was swinging at though, thanks for the correction.
Old Feb 25, 2019 | 10:59 AM
Gjcb1976's Avatar
Gjcb1976
Any idea where the PCM is located on the 2003? I've been searching online and haven't had any luck yet.
Old Feb 25, 2019 | 11:26 AM
R&T Babich's Avatar
R&T Babich
It very well could be in the CJB and Ford may not consider it "serviceable" but soldered to the board or modular they all still function and can fail in the same way. The PCM relay is definitely more specifically what I have in mind. ....
I thought you meant a relay for the PCM, just wanted to clarify.
There are several "Hot at all times" relays, i.e. fuel pump, AC, headlights, seats, etc.
Seems odd the PCM relay does not have a fuse between it and the battery.
Fords idea of soldering the fuel pump relay to the bottom of the CJB is just lame.
The fuel pump relay gets opened/closed twice as often as any other relay per trip - once to prime the fuel rails and again to run.
And now that the relays are getting worn out the "serviceable" replacement assembly, the CJB, has been discontinued.
ajzalesx
Sep 5, 2015 05:13 AM
JW1971
Nov 12, 2014 10:16 PM
Haines Hooter
Feb 23, 2013 10:43 PM
Scott Johansen
Feb 20, 2012 07:50 PM
BlueHeavyD
16
Jan 13, 2004 11:09 PM
