2005 Excursion: water in cup holders in center console
To my horror today I noticed water in
the center console’s cup holders in my
2005 Excursion Eddie Bauer edition v10.
Nothing else appeared wet nearby, just
very slightly damp, as of water had been
there before.
Haven’t driven the car in a week.
See the picture I uploaded.
Is this a known problem and how could
it have happened? Never happened
before. Any repair ideas? Don’t want it
to happen again. Thanks in advance.
(Ignore the plastic on the floor.
That’s there from when the dealer
sold me the truck.)
there before.
sold me the truck.)
I've seen this before. Your windshield sealant has failed and is leaking at the top center of the windshield. This is going to mean RUST when you pull the windshield off. DO NOT go to a glass company, as they will pull the windshield and then tell you they cannot put a new one on until you fix the rust. Take it straight to a body shop that can mitigate the rust that you will find under there.
The water is being directed to the cupholders by the overhead console.
Until you figure out where the water came from, you’re not in the clear.
Looks like you’re in the south based on the trees in the back ground. Take a hose and soak the top and windshield and then look in the car for dripping. Maybe first lay some open newspaper all across the front seat so you can hear and see any dripping better.
What Seville said.
For water to end up in the cup holders (and no one else has been in there but you), it has to come from the overhead console. A couple years ago, someone had this same exact scenario, and it was his windshield pinch weld that had rusted through and was routing the water into the console and then to the cupholders/carpet. You could lay out the newspaper, or you can pull the headliner down to see the pinch weld. Easier to do the newspaper...
I can agree with Nicmike's comments a 100% from personal expeirence of this happening on my first Expedition.
the windshield had a bad seal and it is leaking through the overhead console, I watched it drip on a rainy day, and pulled the console to get a look while it was doing it.
when I pulled the rubber off the windshield I only had a couple spots with minimal surface rust. So I cleaned them up and painted, then saw a hack on youtube about leaky windshields. You get the windshield sealer they sell at the parts stores, a very liquid one like water not gel/caulk, use q tube or two around the whole windshield.
the more watery stuff hopefully seeps into your failed seal and reseals it. Then use the more gel/caulk like windshield sealer to make sure the rubber seal is securely sealed.
Worked for me on the Expedition, about an hour of my time and $20 and I never had the problem again.
It is the urethane, but if the paint under the urethane isn't great moisture gets under it, deteriorates the metal, and you start to get leaks. You can then try to seal the rubber trim to keep the water from getting to the urethane but it's not a permanent fix. Really you need the window removed at a body shop and have that entire interface cleaned up, primed and painted with a quality job to fix it right.
