Crank no Start P0232 and U1900 codes
Old Feb 18, 2019 | 01:34 PM
cyclemanb's Avatar
cyclemanb
Exclamation Crank no Start P0232 and U1900 codes
Please help I am in a bind. My truck all of a sudden started acting funny, rough starting, missing etc. Now it just refuses to start at all. I have a scan gauge II and all the ficm, ipr, sync, and voltages were perfect. It was building oil pressure just fine and should have started. The fuel bowl was filling up and everything. I moved the harness coming from the pcm just to inspect and chaffing and now I cannot even get a reading on the scangauge at all. I have a tune on it and cannot even set it back to stock. Does anyone know a good diesel mechanic that is reputable here in the Dallas (specifically Plano) area? I want to tow it to someone who knows what they are doing on these trucks as it seems to be an electrical issue. Thanks.
Old Feb 18, 2019 | 06:17 PM
bismic's Avatar
bismic
P0232 - Fuel pump secondary circuit high. Voltage is detected to be present at the fuel pump monitor circuit when it has not been commanded "on" for more than one second. Short to power or sticking relay (which is integral to the CJB).
Old Feb 21, 2019 | 10:43 AM
cyclemanb's Avatar
cyclemanb
Thumbs up Fixed
I had tried diagnosing this on my own but the problem was intermittent and seemed to point to something electrical in nature. I had drained the HFCM from the water separator and next thing I knew it ran great......for a day. Then it died and would not restart. It was cold and raining outside so I ended up towing it to Plano Diesel and they diagnosed it as the HFCM fuel module on the drivers frame rail. They replaced it and it started right up and is running great. I no longer have long crank cold morning starts. My fuel mileage has gone way up! If I ever see that P0232 code again I will look at the HFCM first. Maybe this will be helpful to someone else. Thanks
Old Feb 21, 2019 | 10:51 AM
bismic's Avatar
bismic
Glad you have it fixed.
Edit - This type of failure really can be any of what I posted (relay, wiring, or pump). The next guy may not have an HFCM issue. It really does take some "legwork" to avoid guessing.
jgw028
1997 - 2003 F150
Oct 2, 2016 07:31 PM
drbmw2002
Apr 13, 2012 10:41 PM
DirtDiver52
Mar 14, 2012 07:41 AM
RangerSaint
1983 - 2012 Ranger & B-Series
Feb 17, 2012 02:10 AM
arib
1978 - 1996 Big Bronco
15
Jul 2, 2006 12:30 PM
