Which CPS?
Old Feb 17, 2019 | 11:18 PM
matthoov's Avatar
matthoov
Which CPS?
I'm trying to verify which CPS is best for my '97 F250HD w/7.3L PS. I have read that the F4TZ-12K073-C (blue) is the best one but multiple sources say it won't fit my truck but I have also seen that it will. The same sources say the F4TZ-12K073-B (gray) one will fit but supposedly they are not as good. Not sure if the reason is because 1997 was the changeover year for the F250 but mine is the older style. I don't know if they are actually different in length going into the engine but I sure want to make sure that I have proper clearance to the cam. Thanks, Matt
Old Feb 18, 2019 | 04:48 PM
Hussler's Avatar
Hussler
The newest and best is dark gray with a purple o-ring. You can get this directly from Ford, International, Riffraff Diesel and probably some other vendors. There are probably a half dozen different versions out there on the market, don't skimp out with the older versions. Way back when a shimming kit was available to measure cam to end of CPS but nobody does that anymore. Instead the CPS was improved internally (electronically) to eliminate the difference's in length. Original CPS was black and is the best of the best but no longer available, anywhere.
Old Feb 18, 2019 | 08:45 PM
matthoov's Avatar
matthoov
Thanks for the info and Riffraff had good info as well that I hadn't seen before regarding the CPS. Got it ordered.
lawdawg79
Dec 11, 2015 08:28 PM
dn29626
Aug 27, 2012 10:05 PM
4inchlovin
26
Apr 7, 2012 08:35 PM
jakemb
Feb 12, 2007 01:00 AM
shendoa
Feb 13, 2004 06:51 AM
