Fuel Issue? Helppppp
Old Feb 18, 2019 | 11:14 AM
Kadin Cook's Avatar
Kadin Cook
Originally Posted by fordpride
Have you checked the uvch?
Replaced both, and pig tails.
Old Feb 18, 2019 | 11:15 AM
Kadin Cook's Avatar
Kadin Cook
Originally Posted by Edgethis
That last post sure sounds like the cankshaft sensor, down by the balanacer.
ive replaced it twice now. Both times it didnt change anything so i put the stock one back in cause aftermarket is junk.
Old Feb 18, 2019 | 11:17 AM
Kadin Cook's Avatar
Kadin Cook
UPDATE:
I have the scanner hooked up right now and my ICP psi was hovering between 800-900 and my IPR % was at 16. But after sitting here letting it idle they both have dropped to where they should be. Is that normal? If not then what could cause that?
Old Feb 18, 2019 | 11:39 AM
Kadin Cook's Avatar
Kadin Cook
Originally Posted by Kadin Cook
UPDATE:
Also i just did an injector buzz test and I got a P1271, P1272, and P1277 which is the “high to low side open” on injectors 1, 2, and 7. I’ll probably start a new thread about these codes.
Old Feb 18, 2019 | 01:22 PM
Hussler's Avatar
Hussler
UPDATE:
Yes, it is normal on a cold start.
Old Feb 18, 2019 | 02:06 PM
Kadin Cook's Avatar
Kadin Cook
Kind of figured. Thanks!
DentsideCurtis
Nov 8, 2016 10:36 AM
railwelder1987
Oct 3, 2015 07:19 AM
bigbeariron
Jan 21, 2012 05:11 PM
mercman86
13
Dec 1, 2009 01:35 AM
luthrobediesel
Aug 18, 2009 02:19 PM
