Charge Indicator
Old Feb 17, 2019 | 04:40 PM
HVFDFIREFIGHTER1618's Avatar
HVFDFIREFIGHTER1618
Charge Indicator
in the attached picture just under the light socket is the charge indicator. The book tells how this works. There is a wire running through a metal loop. The wire is cloth coated and in bad shape. Can I replace this with a new same size stranded wire coated with I think rubber? Will the gauge still work?
Old Feb 17, 2019 | 04:43 PM
HVFDFIREFIGHTER1618
Will get photos soon. Having some issues uploading
Old Feb 17, 2019 | 04:53 PM
HVFDFIREFIGHTER1618
Old Feb 17, 2019 | 05:01 PM
pbsdaddy's Avatar
pbsdaddy
If you aren't converting to 12 volt, make sure you use the same gauge wire that was there originally. Also, make sure the wire goes through the loop in the same direction it did originally. If not, the gauge won't work. The diagram , in the article you posted, shows the proper direction of flow. But, to answer your question, yes, a wire with rubber coating will work just fine. The gauge works because the loop picks up the electromagnetic "flow" through it.
Old Feb 17, 2019 | 05:11 PM
Jersey devil's Avatar
Jersey devil
Denny’s reply above is correct. If the gauge shows discharge instead of charg you know the wire is going thru the loop in the wrong direction.
Good luck,
Tom
Old Feb 18, 2019 | 03:55 AM
Badmoonreizen's Avatar
Badmoonreizen
Correct, the gauge is inductive, and senses the current going through the loop.
Regards, Mark.
Old Feb 18, 2019 | 06:04 AM
Mixer man's Avatar
Mixer man
Yes. The meter uses the Hall Effect principle so there is no electrical connection, and you can use any gauge wire as long as it is the same AWG size or heavier. There is no real need for extra insulation as the new wire insulation will be quite adequate. I'm currently using AWG 6 because of anticipated high loads. What is critical though is the direction the wire passes through the loop. Make sure it goes the same way as the old wire otherwise the meter will read backwards
emgee
Mar 31, 2016 06:17 PM
Tyler S
May 10, 2014 08:40 PM
iwanaflattie
19
Dec 3, 2010 06:45 PM
460429_freak
Apr 11, 2007 12:59 PM
Oregon Bob
Sep 14, 2006 11:52 PM
