Bowed Tailgate 61 Shortbed
Old Feb 14, 2019 | 04:36 PM
Srowe's Avatar
Srowe
Any thoughts on how to remove a bow in a tailgate..
The top tube of the tailgate bas about 1/2-3/4” bow.
Scott
Old Feb 14, 2019 | 04:49 PM
TA455HO's Avatar
TA455HO
Lead Gopher
I've used a 30-ton press before. Support the ends of the gate on large blocks of wood with the bow upward and press down in the middle. I have had to go a little past the sweet spot before since as you let up on the pressure from the press it wants to spring back some. I strapped the gate to the blocks of wood on either end so it couldn't tip since I was only pushing on the top edge, too.
Chad
Old Feb 14, 2019 | 05:36 PM
Srowe's Avatar
Srowe
Chad
did it damage the tube
Old Feb 14, 2019 | 10:56 PM
RangerMercMan's Avatar
RangerMercMan
The word "tube" you are using is suggesting to me that you have a Flareside tailgate. Chad's idea is good however, I would consider slipping another bar of metal inside your "tube" as a snug fit. This second tube will help prevent kinking the tailgate tube when pressing down on it.
Old Feb 16, 2019 | 09:32 AM
FuzzFace2's Avatar
FuzzFace2
The used gate I got for my 81 flare side also had a bow.
I placed the gate on the floor and used 2x4's at either end and "I" was able to "bounce" (250+ lb) a little in the center to get it flat.
I also had a long level to check if it was flat or needed a little more "bounce".
Its working for me.
I don't thing this could be done to a style side gate.
Dave ----
Old Feb 18, 2019 | 05:56 AM
Srowe's Avatar
Srowe
Its working for me.
Dave ----
thanks everyone
CHUCKS65PHUGLY
Jun 23, 2006 09:06 PM
rhw
Aug 2, 2005 02:07 AM
laynrubber
May 29, 2004 08:47 AM
todd_adams2001
Sep 15, 2002 03:01 PM
jaye
May 7, 2001 11:19 AM
