02 door ajar switch
Old Feb 14, 2019 | 01:02 PM
tjc transport's Avatar
tjc transport
i ain't rite
02 door ajar switch
is there any way to determine which door ajar switch is bad by using autoenginuity or forscan, or any other program?
my 02 supercab has the light lit in the dash and spraying the switches has not worked turning it off...
Old Feb 14, 2019 | 03:39 PM
timmyboy76's Avatar
timmyboy76
With all other symptoms i had with my 02..(radio on, courtesy light on, windows no worky), i ojmed out each ajar wire at the VSS.
Old Feb 15, 2019 | 01:19 AM
bigreentruck's Avatar
bigreentruck
My driver side latch would often times not latch closed with the windows closed. Good weather seals.Had to slam driver door.
Got tired of it. Lubed the little latch fork mechanism and it is better. Shoot some WD or other lube/cleaner into whatever hole you can find for the internal mechanism as well.
Old Feb 15, 2019 | 06:46 AM
tjc transport
i ain't rite
i have sprayed both doors numerous times and did the open/slam shut thing.
this truck is no longer a daily driver, and i would rather not have to pull both doors apart to change the switches.
because i know for a fact it will not be the first switch i attempt to change,.
Old Feb 16, 2019 | 07:28 AM
tjc transport
i ain't rite
i had a thought last night. the bad switch will not turn the light on when door is opened, because it is already closed.
so i tried this morning. passenger door open no interior light.
driver door open, interior light comes on.
so this tells me the passenger door switch is the bad one.
Old Feb 17, 2019 | 09:38 AM
'88 E-350's Avatar
'88 E-350
You already found it so I'm late to the party, but the 'self test' feature in the instrument panel will tell you which one it is. With the key off hold down the odo reset button and turn to run and keep holding the button 'till it goes into test mode. Then you toggle the button to cycle through different stuff and one of them is the door sensors, it'll tell you which are open closed. It displays them in a numerical code, you could find which number is which door or just open/close the doors and see which one doesn't trigger a change in the display.
Old Feb 17, 2019 | 12:27 PM
Bill De's Avatar
Bill De
Wow I never knew we had a test mode. Now I have to go try it.
Old Feb 17, 2019 | 01:01 PM
tjc transport
i ain't rite
same here. i used autoenginuity the few times i had an issue.
Old Feb 17, 2019 | 02:17 PM
Walleye Hunter's Avatar
Walleye Hunter
Do they all have a test mode or do the later trucks have digital dashes and only those have it?
Old Feb 17, 2019 | 05:23 PM
'88 E-350's Avatar
'88 E-350
If it has a digital odometer it probably has the capability, my '02 Ex does.
Old Feb 17, 2019 | 05:53 PM
tjc transport
i ain't rite
04 started digital odometers in all pickups.
my 02 diesel had digital odometer because it is an XLT. the 2000, 2001, and 2002 XL's had analog speedo.
Old Feb 17, 2019 | 06:46 PM
burnthelight88's Avatar
burnthelight88
94 started digital odometers in all pickups.
Wrong. Late 99 analog odometer here in an XLT.
Old Feb 17, 2019 | 08:30 PM
Walleye Hunter
My '01 parts truck has analog also.
Old Feb 17, 2019 | 09:58 PM
AllaboutMPG's Avatar
AllaboutMPG
yep 2000 XLT with analog
Old Feb 18, 2019 | 07:13 AM
tjc transport
i ain't rite
correct you all are. fat fingers here hit 9 instead of 0
04 was the start of all digital.
