Dash cam
Old Mar 9, 2019 | 06:53 PM
  #31
Firefighter 1406's Avatar
Firefighter 1406
What size SD cards do you guys run? And how long can they record for? Are they set to overwrite? Or do you have to pull the card and delete it?
Old Mar 9, 2019 | 06:57 PM
  #32
sdetweil's Avatar
sdetweil
I gave a 64 gig, which gives me about 5 days with both front and rear cameras at 1080 resolution. It overwrites
https://www.amazon.com/Veckle-Channel-Dashboard-Recorder-Recording/dp/B0746BCFBF/ref=as_li_ss_tl?ie=UTF8&qid=1539634946&sr=8-3&keywords=mini+0906&linkCode=ll1&tag=dcr-dual-20#customerReviews
Old Mar 9, 2019 | 10:08 PM
  #33
wrvond's Avatar
wrvond
I think the card that’s in there right now is 64 gigs. It over writes but not over “events”. I format the card every couple weeks by pushing a button on the side of the front camera. That deletes marked events. Since I don’t have cloud available, I have to put the micro SD card in a computer to download any updates or if I want to save videos. I can download videos to my phone or tablet, but it’s much faster to copy them over on a computer.
Blackvue SD750 dual channel.
Old Mar 11, 2019 | 02:23 AM
  #34
2009kr's Avatar
2009kr
Originally Posted by Bohen
What amp fuses did you use ?
The wire for the camera is small, so I used a 5A (not the 15 that came with the tap).
Old Mar 11, 2019 | 05:56 AM
  #35
Bohen's Avatar
Bohen
thank you sir .
Old Mar 11, 2019 | 08:58 AM
  #36
wrvond's Avatar
wrvond
Probably depends on the camera. My DR750 calls for 20 amp fuse.
I plugged it in to a 20 amp circuit and used a 20 amp micro fuse.
Old Mar 11, 2019 | 09:05 AM
  #37
sdetweil's Avatar
sdetweil
I connected to the fused PTO wire. Cameras draw less than half an amp running
Old Mar 12, 2019 | 06:06 PM
  #38
2009kr's Avatar
2009kr
I have the DR900 2-channel system. The most it draws is just over one amp. There is no way I'd want a wire that thin under my A-pillar trim and under my headliner with a 20 amp fuse. I don't know the gauge, but it definitely isn't rated for a 20 amp draw. I doubt you'd ever have an issue, but I like to fuse circuits for the weakest link - and that thin wire is it.
Old Mar 14, 2019 | 10:11 PM
  #39
wrvond's Avatar
wrvond
My camera isn’t plugged into the fuse block. It’s plugged in to the Cell Link Neo battery. The battery is connected to the fuse block and installation instructions called for a 20 amp fuse.
So I wasn’t exactly correct in my earlier post.
Old Mar 31, 2019 | 04:36 PM
  #40
MPNX2's Avatar
MPNX2
Blackvue DR900 2ch 4k. All wires are hidden above the roof liner and A pillar trim.
Windshield position isn't viewable by driver. I had to flip the camera to get the lens farther from the mirror for an unobstructed view.
Back camera must be on this side due to sliding window.
Passenger well fuse panel for both ignition switched and always-on power.
Power control box by fuse panel cover is set to turn off if voltage drops below 12v or after 12 hours.
What do you mean by flip the camera?
bittondb
Jan 5, 2019 01:45 PM
Colorado_Kid
General Automotive Discussion
Sep 19, 2018 05:19 PM
LiquidSteam
Jul 1, 2017 12:23 PM
johnkn
2015 - 2020 F150
Sep 2, 2015 08:57 PM
SpringerPop
May 19, 2013 06:44 AM
