390 Engine Build and Add On
Could someone please help me compile a list of everything needed to add to a 390 crate engine to make it a "dressed engine" or "drop in engine"?
I want to make sure i am not leaving anything out.(brand names aren't needed) example- wiring harness, exhaust, pullies, etc..
any and all help is welcomed!
i havent bought the motor yet. ive been looking and just want to make sure im getting everything i need. ite for my 1969 ford F100. i want to go with the 390 in it
You'll want a new damper and motor mounts. Also, if the new 390 does not come with an intake installed then you'll want to check fit of what ever intake you want to install to prevent vacuum leaks and/or oil consumption.
Wanna save some time & headaches? Try these..
Survival Motorsports Home Page
https://www.customcrateengines.com/engines/ford.html
https://craftperformanceengines.com/Category/FFE
https://www.coasthigh.com/Ford-351-W...tors-s/102.htm
May not not be in your $$ ballpark but....sure simplifies things.
Dan
Dan
Engine, did you get a crate engine?
WildF4u
Oct 27, 2014 10:23 PM
9299Fords
Apr 5, 2008 08:50 AM
The67Beast
Oct 26, 2004 06:53 PM
denisontexas
May 23, 2004 03:26 PM
