Coolant leak from intake ??
Old Feb 12, 2019 | 09:56 PM
Dutter 2's Avatar
Dutter 2
So 2 weeks again I replaced my primary radiator and now another leak popped up. It looks to be coming from this possible intake manifold. It’s below my upper hose and blow the plastic housing. And I can’t seem to find a good procedure on removing the intake manifold
Old Feb 13, 2019 | 07:22 AM
Just Strokin's Avatar
Just Strokin
How about some photos where you are not zoomed in do tight? Unless one is whiz on components and their locations on the engine, the above photo leaves most scratching their heads.
Old Feb 13, 2019 | 09:04 AM
Dutter 2's Avatar
Dutter 2
It’s in such a tight spot that’s honestly the best picture I could try to get
Old Feb 13, 2019 | 09:28 AM
Just Strokin
I understand you trying to get a photo of the leak but what about an overall photo showing the area. Maybe someone pointing to the area you think is leaning. Photo about a foot or two away or both distances.
Old Feb 14, 2019 | 12:22 AM
Dutter 2's Avatar
Dutter 2
After looking into it some more it looks like there is a coolant cross over tube that’s the source of the leak. But still can’t find a good Procedure
Old Feb 14, 2019 | 04:01 PM
Just Strokin
Here is the Ford Workshop DVD procedure.
Old Feb 15, 2019 | 10:20 AM
U9000's Avatar
U9000
To help with everyone's alignment, the photo posted above is sort of upside down. The top of the picture is the front of the engine and the bottom is the back. The black line on the right is the coolant hose from the top of the radiator and the gray line crossing over the upper left is the hot intake headed to the intercooler.
I'd be suspect of the sensor that's right there. Pull the connector and see if there's a/f in it.
Old Feb 16, 2019 | 04:24 PM
Dutter 2's Avatar
Dutter 2
Sweet that helps. Looks like gasket 6 is what’s leaking. And I looks at everything above that gasket and didn’t see a leak. Only at that gasket
jayron
1997 - 2003 F150
Mar 3, 2019 08:04 PM
Rennisreaper
Oct 4, 2017 10:52 PM
Gage2502
Sep 20, 2015 10:16 AM
lostonmonday
21
Jun 12, 2013 04:51 PM
GFDHoytJr
Apr 22, 2004 03:10 PM
