NEED TURBO HELP PLEASE
Old Feb 12, 2019 | 12:00 PM
davida7777's Avatar
davida7777
Exclamation NEED TURBO HELP PLEASE
i just finished a long repair that took long because i had to wait to get paid and wait for parts. a few months sitting near tampa florida. i replaced the oil cooler and two injectors, the radiator also........the turbo was stuck till i drove down the street and back. i heard it break loose. its sticking a little. the problem is its making a loud sandpaper like sound only when i press the gas and sticks sometimes. will it clear up thru daily driving or is there something i can do? do i need to crack it open and clean it? will i need a new turbo?
Old Feb 12, 2019 | 12:17 PM
87crewdually's Avatar
87crewdually
Anytime I have a turbo off it comes apart. It's not hard or time consuming.
If you know there is a problem with the unison ring sticking than the turbo has to come off and disassembled, cleaned, & reassembled to know its cured when you're done.
Old Feb 12, 2019 | 12:23 PM
davida7777's Avatar
davida7777
Is it safe to drive till this weekend?
Old Feb 12, 2019 | 04:17 PM
87crewdually
It should be for a few days. A prolong repair of a stuck unison ring can result in excessive wear of the actuator pin hole and excessive or low boost, depending where it sticks and when.
Old Feb 12, 2019 | 04:20 PM
davida7777's Avatar
davida7777
Why does it sound so ****ty? Like sandpaper
Old Feb 12, 2019 | 05:06 PM
87crewdually
Are you sure it's the unison ring making noise and not a wore bearing and the blades are hitting the housing or something?
I don't know what you mean it sounds like sandpaper.
Are you sure you don't have a boost or up-pipe or Y-pipe leak?
Old Feb 12, 2019 | 06:02 PM
davida7777's Avatar
davida7777
It sounds like a bearing to me. Would a rebuild kit solve it or do I need a need turbo?
You think it's safe to drive?
Old Feb 12, 2019 | 06:03 PM
87crewdually
I would not drive it. I would remove it, inspect for the cause, then take action of order parts or if damage is severe buy a replacement turbo.
Old Feb 13, 2019 | 05:01 AM
Yahiko's Avatar
Yahiko
I second that.
You really don't want a turbo to grenade on you and destroy internal parts.
Old Feb 13, 2019 | 11:49 AM
davida7777's Avatar
davida7777
I ordered a new turbo and its parked. thanks for help
stambj
6.7L Power Stroke Diesel
Oct 23, 2018 08:14 PM
cookingguy
Dec 11, 2016 12:47 PM
Shesalonewolf
General Automotive Discussion
Jun 28, 2004 02:32 PM
TurboTuff
Dec 22, 2002 04:08 PM
