53 Ford F500 Engine
Old Feb 11, 2019 | 06:34 PM
HVFDFIREFIGHTER1618's Avatar
HVFDFIREFIGHTER1618
53 Ford F500 Engine
What is this device under the carb? It appears to be weighted on one side. Should it turn freely?
Old Feb 11, 2019 | 06:43 PM
HVFDFIREFIGHTER1618
On the passenger side I can see this green cover(the one behind he coil, not the valve cover). I can also see some kind of silicone sealant. I’m sure that should be a gasket of some sort. To get this cover off, I would remove the three nuts. Do I need to drain oil or coolant from the engine first? What would this gasket be called so I can order a new one. The engine is a straight 6 215. It says “Cost Clipper 6” on it
raytasch's Avatar
raytasch
Believe Nothing
That is a heat riser of "butterfly" type. It should be free to turn. The weight keeps the valve closed at low engine speed and little exhaust flow.
Nicely preserved decals, BTW. Careful when you clean them.
No need to drain any fluids when you remove that side cover.
Old Feb 11, 2019 | 06:46 PM
HVFDFIREFIGHTER1618
I will have to clean the heat riser up a little it turns fairly free but I can feel some drag in it. It does have a coil spring connected to it.
Old Feb 11, 2019 | 06:53 PM
HVFDFIREFIGHTER1618
I also need to replace the ignition switch. How do intensive the chrome bezels and switch. When I get the new switch, it looks like I also need to get a new key core that goes into the switch or can I just get one complete unit? Is there a a special tool to remove the bezels?
Old Feb 11, 2019 | 07:04 PM
HVFDFIREFIGHTER1618
In the above picture, u can see the blower switch. It feels like a low and a high pull. The book shows four pulls a heater switch, temp control, air control and defroster control.
Book says three types of heaters were used but only has two listed- a fresh air heater and a recirculating type.
Old Feb 11, 2019 | 07:06 PM
HVFDFIREFIGHTER1618
Old Feb 11, 2019 | 07:07 PM
HVFDFIREFIGHTER1618
Mine does not have a plenum chamber. It looks to be more of a cube shape.
Old Feb 11, 2019 | 07:13 PM
bigwin56f100's Avatar
bigwin56f100
three heaters for 53
the one you have was installed by the dealer as your truck has a heater delete plate on the firewall. The plate was only installed on heater delete trucks
second heater is a 2 control ( blower and defrost) recirculating heater meaning it reheats air from inside cab
third heater is the one you have pictured. It is a deluxe fresh air heater 4 control ( air, temp, blower, defrost) it utilizes the louvers on the side of the cowl for fresh air to be heated
Old Feb 18, 2019 | 11:06 AM
HVFDFIREFIGHTER1618
Anyone know what that green side cover is called? I need to order the gasket for it.
Old Feb 18, 2019 | 11:25 AM
EffieTrucker's Avatar
EffieTrucker
Phantom of the Phorum
Believe it or not, it's a "Side Cover". (Sometimes called a pushrod cover)
Arizona84F150
Nov 3, 2017 04:41 AM
90trunk
2015 - 2020 F150
Sep 2, 2016 11:24 AM
Santimanzano
Aug 10, 2016 09:52 AM
trozei
Mar 30, 2015 06:58 PM
